[Darshan-users] Darshan & IPM results not the same
Vineet Soni
vsoni at mercator-ocean.fr
Mon Nov 8 04:05:19 CST 2021
Hello,
I am trying to analyze the IO behavior of our codes with Darshan.
Darshan: 3.3.0
Compilers: Intel 2018
MPI: Intel MPI 2018
FS: Lustre (lustre-module disabled in Darshan configuration)
Darshan profiling: LD_PRELOAD
I observe a big difference in IO results from Darshan and IPM (v2.0.5) for one of our codes. I guess that both profilers are not profiling the same POSIX calls?
The POSIXIO calls profiled in IPM are:
fopen, fdopen, freopen, open, open64
fclose, close
fflush
fread, read
fwrite, write
fseek, lseek, lseek64
ftell
rewind
fgetpos, fsetpos, fgetc, getc, ungetc
creat
truncate, ftruncate, truncate64, ftruncate64
While the ones profiled by Darshan are: https://github.com/darshan-hpc/darshan/blob/main/darshan-runtime/lib/darshan-posix.c ?
However, the huge difference is observed in the “read” call, which exists in both the profilers.
| | IPM | Darshan |
| Read (s) | 324.57 | 6.02 |
| Agg. Read (count) | 34 766 456 | 2 946 271 |
I tested Darshan and IPM with other codes (reading NOT the same files) to check if this issue is faced in them as well. But, I got the same results.
So, I don't understand what could be the reason that this application is not giving the same results.
Do you have any idea of why this could happen?
Thanks in advance.
PS: The application does a lot of IO, and is expected to spend a significant time in read operations.
Best regards,
Vineet
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20211108/6642bfe8/attachment.html>
More information about the Darshan-users
