[Darshan-users] Logs not generated inspite throwing warning message
Harms, Kevin harms at alcf.anl.gov
Mon Jun 21 11:18:02 CDT 2021
Hassan,
  did you create the  /darshan-logs directory? Looks like it might not be writeable.
  try: /darshan-logs/2021/6/21
  if you want to try a quick test, set DARSHAN_LOGFILE to the path/name of the log, like:
  DARSHAN_LOGFILE=/path/I/can/write/to/logfile.darshan
kevin
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Hassan Asghar <haxxanasghar at gmail.com>
Sent: Monday, June 21, 2021 12:35 AM
To: darshan-users at lists.mcs.anl.gov
Subject: [Darshan-users] Logs not generated inspite throwing warning message
I am running darshan with mpich on a three-node cluster and my job executed successfully but not generated logs. error warning is given below at the end of the execution.
[haxxanasghar at gpuserver2 ~]$ mpiexec -n 64 -f machinefile -env LD_PRELOAD /usr/l        ocal/lib/libdarshan.so ./MADbench2 640 80 4 8 8 4 4
MADbench 2.0 IO-mode
no_pe = 64  no_pix = 640  no_bin = 80  no_gang = 4  sblocksize = 8  fblocksize =        8  r_mod = 4  w_mod = 4
IOMETHOD = POSIX  IOMODE = SYNC  FILETYPE = UNIQUE  REMAP = CUSTOM
S_cc         0.02   [      0.02:      0.03]
S_bw         0.01   [      0.01:      0.01]
S_w          0.03   [      0.03:      0.04]
S_total      0.07   [      0.07:      0.07]
W_cc         0.04   [      0.03:      0.05]
W_bw         0.22   [      0.20:      0.23]
W_r          0.02   [      0.02:      0.02]
W_w          0.01   [      0.01:      0.01]
W_total      0.28   [      0.28:      0.29]
C_cc         0.01   [      0.01:      0.01]
C_bw         0.00   [      0.00:      0.00]
C_r          0.01   [      0.01:      0.01]
C_total      0.02   [      0.02:      0.02]
dC[0] = 0.00000e+00
darshan_library_warning: unable to create log file /darshan-logs/2021/6/21/haxxa        nas_MADbench2_id29484-29484_6-21-52165-1341319014666854881.darshan_partial.
Hassan Asghar
MS Computer Science
Mobile: +92-321-1741755
Personal Website: http://bit.ly/2OQ0egs
Google Scholar: https://bit.ly/3lVYuxF
More information about the Darshan-users mailing list
