[Darshan-users] Unable to create log:
Harms, Kevin
harms at alcf.anl.gov
Mon Jul 19 11:17:23 CDT 2021
Hassan,
this error "darshan_library_warning: unable to create log file /home/haxxanasghar/darshan-logs/2021/7/15/haxxanas_MADbench2_id17444-17444_7-15-65476-1341319014666854881.darshan_partial."
seems like a either a permissions problem or there directory structure doesn't exist. Are you sure this exists?
ls -l /home/haxxanasghar/darshan-logs/2021/7/15
kevin
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Hassan Asghar <haxxanasghar at gmail.com>
Sent: Saturday, July 17, 2021 3:41 AM
To: Snyder, Shane
Cc: darshan-users at lists.mcs.anl.gov
Subject: Re: [Darshan-users] Unable to create log:
No, it doesn't works.
Hassan Asghar
Ph.D Scholar
Mobile: +821096861912
Personal Website: http://bit.ly/2OQ0egs
Google Scholar: https://bit.ly/3lVYuxF
On Fri, Jul 16, 2021 at 7:25 PM Snyder, Shane <ssnyder at mcs.anl.gov<mailto:ssnyder at mcs.anl.gov>> wrote:
Hi Hassan,
Would you try setting the following environment variable prior to running your application?
export DARSHAN_LOGHINTS="romio_no_indep_rw=true;cb_nodes=1"
Maybe that will work out better when writing Darshan logs to an NFS mount.
--Shane
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov<mailto:darshan-users-bounces at lists.mcs.anl.gov>> on behalf of Hassan Asghar <haxxanasghar at gmail.com<mailto:haxxanasghar at gmail.com>>
Sent: Thursday, July 15, 2021 4:14 AM
To: darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov> <darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov>>
Subject: [Darshan-users] Unable to create log:
I have three gpus. darshan and darshan-logs are installed and shared via nfs. all permissions are set. I don't know why logs are not created:
[haxxanasghar at gpuserver2 ~]$ mpiexec -n 64 -f machinefile -env LD_PRELOAD=/home/haxxanasghar/darshan/darshan-runtime/lib/libdarshan.so ./MADbench2 640 80 4 1 8 4 4
MADbench 2.0 IO-mode
no_pe = 64 no_pix = 640 no_bin = 80 no_gang = 4 sblocksize = 1 fblocksize = 8 r_mod = 4 w_mod = 4
IOMETHOD = POSIX IOMODE = SYNC FILETYPE = UNIQUE REMAP = CUSTOM
S_cc 0.03 [ 0.03: 0.03]
S_bw 0.02 [ 0.02: 0.02]
S_w 0.03 [ 0.03: 0.03]
S_total 0.08 [ 0.08: 0.08]
W_cc 0.12 [ 0.07: 0.14]
W_bw 0.77 [ 0.72: 0.85]
W_r 0.02 [ 0.02: 0.02]
W_w 0.01 [ 0.01: 0.01]
W_total 0.92 [ 0.89: 0.95]
C_cc 0.01 [ 0.01: 0.01]
C_bw 0.00 [ 0.00: 0.00]
C_r 0.01 [ 0.00: 0.01]
C_total 0.02 [ 0.02: 0.02]
dC[0] = 0.00000e+00
Hassan Asghar
Ph.D Scholar
Mobile: +82-010-9686-1912
More information about the Darshan-users
