[Darshan-users] Does Darshan uses CPU time ?
Florian Lecomte
flo.lecomte17 at gmail.com
Wed Aug 4 09:35:09 CDT 2021
Hello,
Here is the log I generated, so total_STDIO_F_META_TIME is 67 seconds,
runtime is (end-start+1)=3 seconds (as computed in darshan-job-summary.pl),
and nprocs is 12
So that would mean I have 67 / 36 > 1 Metadata time percentage, which seems
weird.
Is the log file wrong, or maybe the application I want to analyze I/O has a
strange behavior ?
Thank you for your help.
Cordially, Florian
Le mer. 4 août 2021 à 16:26, Harms, Kevin <harms at alcf.anl.gov> a écrit :
> Florian,
> that sounds like an issue. If you can provide the log, we can take a
> closer look at the counters.
> kevin
> From: Florian Lecomte <flo.lecomte17 at gmail.com>
> Sent: Wednesday, August 4, 2021 3:14 AM
> To: Harms, Kevin
> Cc: darshan-users at lists.mcs.anl.gov
> Subject: Re: [Darshan-users] Does Darshan uses CPU time ?
> In fact, what I wanted to know is : how does Darshan get the read times,
> write times and metadata times ? I suppose it uses CPU clocks, but I use
> several nodes, with 2 processes on each node, and each node has 64 cores,
> So I wanted to know if the average time per process was already divided by
> the number of cores too, because cores work in parallel, and so this time
> couldn't be compared with real runtime.
> I can send you the log file later today but basically, I have 36 secs of
> metadata operations, 3 seconds of runtime and 10 processes.
> Thank you.
> Cordially, Florian
> Le mar. 3 août 2021 à 17:20, Harms, Kevin <harms at alcf.anl.gov<mailto:
> harms at alcf.anl.gov>> a écrit :
> Florian,
> STDIO_F_META_TIME should be the time spent in metadata accumulated
> across the processes if it is shared. The rank for the file would be -1 if
> it is shared.
> So for example:
> 4 processes run for 10 seconds
> each process opens foo.txt for 1 second
> 1 process stats foo.txt for 1 second
> the results would be foo.txt shows 5 seconds of meta time for foo.txt.
> So you can do 5 seconds / 4 processes for an average of 1.25s or you could
> do 5s / (10s * 4p) = 0.125 or 12.5%.
> If the rank value is > -1, the the reported time is just for that one
> rank and you need to potentially sum them up.
> If you meta time for a single file exceeds the runtime * number of
> processes, then something must be wrong with the timer collection. Can you
> send the log file? You can also look at the _START_TIMESTAMP and
> _END_TIMESTAMP and see if those agree with runtime or not?
> kevin
> From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov<mailto:
> darshan-users-bounces at lists.mcs.anl.gov>> on behalf of Florian Lecomte <
> flo.lecomte17 at gmail.com<mailto:flo.lecomte17 at gmail.com>>
> Sent: Tuesday, August 3, 2021 9:37 AM
> To: darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov
> Subject: [Darshan-users] Does Darshan uses CPU time ?
> Good evening,
> I'd like to know if I have to divide metrics by the number of CPUs of the
> machine I use if I want to know the percentage of time spent on write
> operations for example.
> Because when I divide for example STDIO_F_META_TIME by [real runtime (time
> spent in "real world") * number of processes], I often get something bigger
> than 1, which is not supposed to happen.
> So to sum it up : Does Darshan give the average metric value per process
> per CPU, or only per process, and so it can not be compared with real spent
> time ?
> Thank you very much.
> Cordially, Florian, student in the HPC field.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20210804/77b51790/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20210804/77b51790/attachment-0001.obj>
More information about the Darshan-users
