[Darshan-users] Darshan v3.2.1 hangs with mvapich2 2.3.3 (IOR)
    Cormac Garvey
    cormac.t.garvey at gmail.com
    Fri Sep 18 13:31:26 CDT 2020
Hi All,
I am unable to get darshan v3.2.1 to work with IOR v3.2.1 built with
mvapich2 v2.3.3.
I am using CentOS 7.7
module load mpi/mvapich2
spack load darshan-runtime^mvapich2
export DARSHAN_LOG_DIR_PATH=/share/home/hpcuser/darshan_logs
export LD_PRELOAD=${DARSHAN_RUNTIME_DIR}/lib/libdarshan.so
TRANSFER_SIZE=32m
SIZE=2G
IO_API=POSIX
IO_API_ARG="-F"
TYPE_IO="direct_io"
TYPE_IO_ARG="-B"
MPI_OPTS=""-np 4 --hostfile $PBS_NODEFILE"
mpirun -genvlist LD_PRELOAD,DARSHAN_LOG_DIR_PATH -bind-to hwthread
$MPI_OPTS $IOR_BIN/ior -a $IO_API -v -i 1 $TYPE_IO_ARG -m -d 1 $IO_API_ARG
-w -t $TRANSFER_SIZE -b $SIZE -o ${FILESYSTEM}/test -O
summaryFormat=$SUMMARY_FORMAT -O
summaryFile=ior_${IO_API}_${TYPE_IO}_${TRANSFER_SIZE}_${SIZE}_${HOST}_${NUMPROCS}.out_$$
The IOR job hangs at the end if I export the darshan LD_PRELOAD (Runs
correctly if I remove the LD_PRELOAD)
When I kill the job, i get the following information in PBS stderr file.
"darshan_library_warning: unable to write header to file
/share/home/hpcuser/darshan_logs/hpcuser_ior_id26_9-18-65156-2174583250033636718.darshan_partial."
The IOR benchmark completes (i.e can see the I/O stats), but does not
appear to exit correctly (remains in a hung state until I kill it)
Running a similar job with IOR+mpich or IOR+OpenMPI works fine with darshan.
Any ideas what I am missing?
Thanks for your support.
Cormac.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200918/effeeb56/attachment.html>
More information about the Darshan-users
