[Darshan-users] profiling DASK application using darshan
Razvan Stefanescu razvan.stefanescu at spire.com
Sun Oct 18 16:33:24 CDT 2020
Hello Sandra,
This is really helpful. Thank you so much!
Razvan
On Sun, Oct 18, 2020 at 1:01 PM Sandra A. Mendez <smendez.fi.unju at gmail.com>
wrote:
> Hi Razvan,
> My python programs were non-MPI for this reason I set up the
> *DARSHAN_ENABLE_NONMPI* variable.
> For a simple python program in my local machine, I executed as follows:
> export LD_PRELOAD=$PATH_INSTALL/darshan/3.2.1-master/lib64/libdarshan.so
> export *DARSHAN_ENABLE_NONMPI=1*
> python images-cla.py
> Another example in a cluster (tensorflow benchmark):
> # I use my Darshan installation so I need to set up LD_PRELOAD in the job
> submission.
> export
> LD_PRELOAD=$PATH_INSTALL/darshan-runtime/3.2.1-master/lib/libdarshan.so
> *export DARSHAN_ENABLE_NONMPI=1*
> horovodrun -np $SLURM_NTASKS $HOSTS_FLAG --network-interface ib0 --gloo *python3.7
> scripts/tf_cnn_benchmarks/tf_cnn_benchmarks.py* --model resnet101
> --batch_size 64 --variable_update horovod
> Thanks,
> Sandra.-
> On Sun, 18 Oct 2020 at 20:30, Razvan Stefanescu <
> razvan.stefanescu at spire.com> wrote:
>> Hello Sandra,
>> What command did you actually use for tracing your python code? Did you
>> use something like
>> mpiexec -n 4 -env LD_PRELOAD $PATH/libdarshan.so python script.py  ?
>> Thank you,
>> Razvan
>> On Sun, Oct 18, 2020 at 7:30 AM Sandra A. Mendez <
>> smendez.fi.unju at gmail.com> wrote:
>>> Hi Razvan,
>>> I have traced a python program by using Darshan. You only need to set up
>>> the DARSHAN_ENABLE_NONMPI variable as follows:
>>> Before running your application. Only a comment, the maximum number of
>>> files to trace by Darshan is 1024 files per parallel task. In case of
>>> python applications, Darshan traces all the files opened not only the
>>> application files (but also the files opened by the python libraries). So
>>> take care if your application overcomes that limit.
>>> Thanks,
>>> Sandra.-
>>> On Sun, 18 Oct 2020 at 15:09, Razvan Stefanescu <
>>>> Hello All,
>>>> Following the documentation note saying that Darshan instrumentation of
>>>> non-MPI applications is only possible with dynamically-linked applications,
>>>> it seems I have to convert the multiprocessing and multithreading DASK code
>>>> to a dynamically-linked code. I know some folks were able to profile Spark
>>>> and TensorFlow codes with Darshan, so I wonder if you could provide some
>>>> suggestions about creating such dynamically-linked code.
>>>> Thank you,
>>>> Razvan
>>>> *RAZVAN STEFANESCU *
>>>> Head of Statistics and Machine Learning Branch
>>>> Senior Data Assimilation and Data Scientist
>>>> *Spire Global, Inc.*
>>>> 1050 Walnut Street, Suite 402, Boulder, CO 80302 USA
>>>> +1-720- <7206432245>*643-2231*
>>>> +1-850-443-1718 <4178491948>
>>>> _______________________________________________
>>>> Darshan-users mailing list
>>>> Darshan-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20201018/a9711fba/attachment.html>
More information about the Darshan-users mailing list
