[Darshan-users] DASK and darshan
Razvan Stefanescu razvan.stefanescu at spire.com
Wed Oct 14 13:06:58 CDT 2020
Hello Shane,
This is much appreciated. Since Darshin works with both Spark or Tensorflow
I should have success with DASK too. For sure I will keep you updated on my
progress.
Thank you,
Razvan
On Wed, Oct 14, 2020 at 10:13 AM Snyder, Shane <ssnyder at mcs.anl.gov> wrote:
> You will also have to set the DARSHAN_ENABLE_NONMPI environment variable
> (i.e., export DARSHAN_ENABLE_NONMPI=1) to ensure logs are generated in the
> case of non-MPI applications. As long as that variable is set, you'll get
> Darshan logs for basically any process running from your shell, so make
> sure you only set it when you really want instrumentation.
> Please let us know how it goes. I've had success getting Darshan working
> with Spark, and I know other users have had success using with TensorFlow,
> so hopefully Dask isn't much of a problem.
> --Shane
> *From:* Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf
> of Harms, Kevin <harms at alcf.anl.gov>
> *Sent:* Tuesday, October 13, 2020 6:53 PM
> *To:* Razvan Stefanescu <razvan.stefanescu at spire.com>;
> darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
> *Subject:* Re: [Darshan-users] DASK and darshan
> Razvan,
>   It's be a couple of years since i used Dask, but you should be able to
> profile by setting LD_PRELOAD=/path/to/darshan/install/lib/libdarshan.so.
>   Please note that Dask will start a process for each python instance so
> you will have a darshan log for each process. A few more caveats, if you're
> using remote processes, I'm not sure if the Dask servers will pass
> environment variables or not. I think Dask has other non-distributed
> schedulers that might work differently if running on a single node.
>   Also note, by default Darshan assumes MPI and depends on it. If you're
> applications aren't using MPI, then make sure you configure darshan with
> the switch --without-mpi.
> kevin
> From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf
> of Razvan Stefanescu <razvan.stefanescu at spire.com>
> Sent: Tuesday, October 13, 2020 4:41 PM
> To: darshan-users at lists.mcs.anl.gov
> Subject: [Darshan-users] DASK and darshan
> Hello All,
> We need to profile some DASK parallel I/O application, and I wonder if you
> can provide an example on how to use darshan to perform such analysis. Your
> help is much appreciated.
> Thank you,
> Razvan
> RAZVAN STEFANESCU
> Head of Statistics and Machine Learning Branch
> Senior Data Assimilation and Data Scientist
> Spire Global, Inc.
> 1050 Walnut Street, Suite 402, Boulder, CO 80302 USA
> +1-720-<tel:7206432245>643-2231
> +1-850-443-1718<tel:4178491948>
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
*RAZVAN STEFANESCU *
*Spire Global, Inc.*
+1-720- <7206432245>*643-2231*
+1-850-443-1718 <4178491948>
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20201014/7598609c/attachment.html>
More information about the Darshan-users mailing list
