[Darshan-users] dxt_analyzer.py: 'invalid continuation byte' error
Harms, Kevin harms at alcf.anl.gov
Mon Oct 12 18:19:02 CDT 2020
Sam,
  I think there was just a misunderstanding on how to use the tools. Please follow this:
  # first parse the DXT log from the darshan log.
  $ ./darshan-dxt-parser ./omlins_a.out_id1174947_10-9-40448-1694713884344482404_1602235659.darshan > parsed-dxt.txt
  # then run the analyzer
  $ python3 dxt_analyzer.py -i parsed-dxt.txt
  # this produces a PDF with the plot
  $ ls *.pdf
  dxt_plot.pdf
  Looking at the plot from run, it looks like you were possibly doing I/O almost constantly during the run.
kevin
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Omlin  Samuel <omlin at cscs.ch>
Sent: Monday, October 12, 2020 8:10 AM
To: Carns, Philip H.; darshan-users at lists.mcs.anl.gov
Subject: Re: [Darshan-users] dxt_analyzer.py: 'invalid continuation byte' error
Hi Phil,
thanks a lot. You can find the file attached.
Cheers,
Sam
Sent: Friday, October 9, 2020 10:37:41 PM
To: Omlin Samuel; darshan-users at lists.mcs.anl.gov
Hi Sam,
I'm not sure off hand what would cause that.  Can you share the log file by any chance (you can send it to me directly if you would prefer not to post it on the mailing list)?  I can try to reproduce on some other systems and see if that narrows down the problem.
thanks,
-Phil
Sent: Friday, October 9, 2020 10:18 AM
To: darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
Subject: [Darshan-users] dxt_analyzer.py: 'invalid continuation byte' error
Hi all,
I have tried the following command both on Ubuntu 16.04 (python 3.5) and on SUSE Linux Enterprise Server 15 SP1 (python 3.6) and got the same error:
$ python3 /usr/local/bin/dxt_analyzer.py -i omlins_a.out_id1174947_10-9-40448-1694713884344482404_1602235659.darshan
Traceback (most recent call last):
  File "/usr/local/bin/dxt_analyzer.py", line 264, in <module>
    for line in infile:
  File "/usr/lib/python3.5/codecs.py", line 321, in decode
    (result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe6 in position 24: invalid continuation byte
With python 2.7.12 (on Ubuntu), I did not get the error, but the generated plot was empty.
Note that the input file does contain values generated by DXT:
$ darshan-dxt-parser omlins_a.out_id1174947_10-9-40448-1694713884344482404_1602235659.darshan | tail -3
 X_POSIX       7   read      197    211527180650      1073741824    804.8381    806.1340  [  0]
 X_POSIX       7   read      198    212600922683      1073741824    806.4404    807.7277  [  0]
 X_POSIX       7   read      199    213674664716      1073741824    808.0719    809.3472  [  0]
Can you fix this / help me to get this working?
Thanks!!
Sam
More information about the Darshan-users mailing list
