[Darshan-users] Cannot create log directory
Jeffrey Layton laytonjb at gmail.com
Mon May 18 15:06:51 CDT 2020
Good afternoon,
I have a small problem when I build Darshan. It doesn't create the log
directory, so I used the script darshan-mk-log-dirs.pl. However, I get an
error:
# ./darshan-mk-log-dirs.pl
Error: could not mkdir /usr/local/darshan-logs//2020.
This is an Ubuntu system I used sudo to run the script and I also tried as
root. In either case, I get the same result.
While I can follow the Perl script (it's been a few years since I last
coded in Perl), I want to make sure I track down the cause of this error.
Thanks!
Jeff
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200518/e6f7c2fb/attachment.html>
More information about the Darshan-users mailing list
