[Darshan-users] trace files can not be created with Darshan
Ayşe Arslan
aysearslan2491 at gmail.com
Tue May 12 13:31:28 CDT 2020
Hello,
I can not create trace files under darshan log directory,
I built in that way,
DARSHAN_LOGPATH=/lustre/nec/ws2/ws/tuner/logs
./configure --with-mem-align=8 --with-log-path-by-env=DARSHAN_LOGPATH
--with-jobid-env=NONE CC=mpicc
--prefix=/lustre/nec/ws2/ws/tuner/darshan-3.1.7-ompi
make
make install
#! /bin/bash
#PBS -N a
#PBS -l nodes=1:ppn=24
#PBS -l walltime=00:40:00
#PBS -o a.txt
cd $PBS_O_WORKDIR
module load compiler/gnu/8.3.0
module load mpi/openmpi/4.0.1-gnu-8.3.0
module load tools/hdf5/1.10.5-openmpi-4.0.1-gnu-8.3.0
export DARSHAN_LOGPATH=/lustre/nec/ws2/ws/tuner/logs
cd /lustre/nec/ws2/tuner/benchmarks/Generators/mkTcTS
LD_PRELOAD=/lustre/nec/ws2/ws/tuner/darshan-3.1.7-ompi/lib/libdarshan.so
mpirun -n 24 ../../../src/MarDyn config.xml
I have 2020/5/12 folders under log directory, configuration was successful,
I got no error after running script, but there is no trace file (.darshan
files)
Any idea?
Ayse
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200512/6b99a073/attachment.html>
More information about the Darshan-users
