[Darshan-users] Darshan & EPCC benchio different behaviour
Piero LANUCARA
p.lanucara at cineca.it
Thu Feb 13 09:21:27 CST 2020
Hi Phil
totally agree.
I really appreciated your support very much.
P.S is it possible to undestand at a more detailed level all the parser
output?
I still have some problem while trying to relate some of those values.
For example, running MPIIO version, the following appears:
1) MPIIO_F_WRITE_TIME 103.772865
2)MPIIO_F_MAX_WRITE_TIME 3.107764
3)MPIIO_F_WRITE_START_TIMESTAMP 22.217328
4) MPIIO_F_CLOSE_START_TIMESTAMP 25.707373
so, is difficult to relate one with two or one with three, four values.
thanks again
Piero
Il 13/02/2020 14:18, Carns, Philip H. ha scritto:
> Thanks Piero. I agree, but from a practical point of view, I don't
> see many options for improving Darshan's handling of this particular
> scenario. If something in the Fortran runtime is impacting perceived
> I/O performance, then the only way to observe it would be to
> wrap/instrument at the Fortran level rather than at the system library
> (libc) level. Otherwise Darshan can't tell the difference between the
> Fortran calls being slow or the Fortran calls being fast with the app
> doing something else in between calls.
> We've been reluctant to pursue that approach (we've hit cases before
> where instrumenting the Fortran level would have been helpful) because
> of the development/maintenance cost, in part because there is so much
> variety in the Fortran compiler world, and in part because our team
> simply doesn't have a lot of Fortran expertise.
> That said, we would entertain a contribution along these lines ��
> Something like that could be enabled as a compile-time option.
> The good news (as you've seen with the MPI tests from benchio) is that
> what you are describing isn't really a problem for the MPI-IO
> interface. Most of the existing MPI-IO Fortran bindings map almost
> directly to the underlying C MPI-IO bindings, meaning that what we
> measure at that level should be a pretty accurate indication of what's
> going on at the Fortran level. The scenario you have hit is an issue
> because the Fortran I/O calls likely have more logic that actually
> resides in the Fortran runtime itself.
> thanks,
> -Phil
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200213/c912c15c/attachment.html>
More information about the Darshan-users
