[Darshan-users] Darshan & EPCC benchio different behaviour
Piero LANUCARA
p.lanucara at cineca.it
Wed Feb 12 08:47:29 CST 2020
Hi Phil.....POSIX
this is a well known benchmark ....you can easily verify it!
by the way it's something like that
! Serial write is unconditionally compiled
subroutine serialwrite(filename, iodata, n1, n2, n3, cartcomm)
character*(*) :: filename
integer :: n1, n2, n3
double precision, dimension(0:n1+1,0:n2+1,0:n3+1) :: iodata
integer :: cartcomm, ierr, rank, size
integer, parameter :: iounit = 10
integer :: i
call MPI_Comm_size(cartcomm, size, ierr)
call MPI_Comm_rank(cartcomm, rank, ierr)
! Write same amount of data as the parallel write but do it all from rank 0
! This is just to get a baseline figure for serial IO performance - note
! that the contents of the file will be differnent from the parallel calls
if (rank == 0) then
open(file=filename, unit=iounit, access='stream')
do i = 1, size
write(unit=iounit) iodata(1:n1, 1:n2, 1:n3)
end do
close(iounit)
end if
end subroutine serialwrite
Piero
Il 12/02/2020 14:13, Carns, Philip H. ha scritto:
> Hi Piero,
> In the serial case, is the rank that's doing I/O still using MPI-IO,
> or is it making calls directly to POSIX in that case?
> The Darshan log for the serial case doesn't show any MPI-IO activity,
> but I'm not sure if that's accurate, or if it's an indication that we
> missed some instrumentation.
> thanks,
> -Phil
> *From:* Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on
> behalf of Piero LANUCARA <p.lanucara at cineca.it>
> *Sent:* Wednesday, February 12, 2020 5:29 AM
> *To:* Snyder, Shane <ssnyder at mcs.anl.gov>; Harms, Kevin
> <harms at alcf.anl.gov>
> *Cc:* darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
> *Subject:* Re: [Darshan-users] Darshan & EPCC benchio different behaviour
> Hi Shane, Kevin
> thanks for the update.
> I attached a new upated files (log and pdf) to this email.
> Also, the log from BENCHIO is attached.
> thanks again
> regards
> Piero
> Il 11/02/2020 20:15, Shane Snyder ha scritto:
> > Definitely looks like something strange is happening when Darshan is
> > estimating the time spent in I/O operations (as seen in the very first
> > figure, observed write time barely even registers) in the serial case,
> > which it is ultimately used to provide the performance estimate.
> > If you could provide them, the raw Darshan logs would be really
> > helpful. That should make it clear whether it's an instrumentation
> > issue (i.e., under accounting for time spent in I/O operations at
> > runtime) or if its an issue with the heuristics in the PDF summary
> > tool you are using, as Kevin points out. If it's the latter, having an
> > example log to test modifications to our heuristics would be very
> > helpful to us.
> > Thanks,
> > --Shane
> > On 2/11/20 8:36 AM, Harms, Kevin wrote:
> >> Piero,
> >> the performance estimate is based on heuristics, it's possible the
> >> 'serial' model is breaking some assumptions about how the I/O is
> >> done. Is every rank opening the file, but only rank 0 is doing actual
> >> I/O?
> >> If possible, you could provide the log and we could check to see
> >> what the counters look like.
> >> kevin
> >> ________________________________________
> >> From: Piero LANUCARA <p.lanucara at cineca.it>
> >> Sent: Tuesday, February 11, 2020 2:28 AM
> >> To: Harms, Kevin
> >> Cc: darshan-users at lists.mcs.anl.gov
> >> Subject: Re: [Darshan-users] Darshan & EPCC benchio different behaviour
> >> Hi Kevin
> >> first of all thanks for the investigation..I did some futher test
> and it
> >> seems like the issue may appear using Fortran (MPI, mainly IntelMPI)
> >> codes.
> >> Is this information useful?
> >> regards
> >> Piero
> >> Il 07/02/2020 16:07, Harms, Kevin ha scritto:
> >>> Piero,
> >>> just to confirm, the serial case is still running in parallel,
> >>> 36 processes, but the I/O is only from rank 0?
> >>> kevin
> >>> From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on
> >>> Sent: Wednesday, February 5, 2020 4:56 AM
> >>> To: darshan-users at lists.mcs.anl.gov
> behaviour
> >>> p.s
> >>> to be more "verbose" I add to the discussion:
> >>> Darshan output for the "serial" run (serial.pdf)
> >>> Darshan output for the MPI-IO run (mpiio.pdf)
> >>> benchio output for "serial" run (serial.out)
> >>> benchio output for "MPI-IO" run (mpi-io.out)
> >>> thanks
> >>> Piero
> >>> Il 04/02/2020 19:44, Piero LANUCARA ha scritto:
> >>>> Dear all
> >>>> I'm using Darshan to measure EPCC benchio benchmark
> >>>> (https://github.com/EPCCed/benchio) behaviour on a given x86 Tier1
> >>>> machine.
> >>>> running two benchio tests (MPI-IO and serial) a different behaviour
> >>>> appear
> >>>> while Darhsan pdf log file is able to recover the estimated time and
> >>>> bandwidth in the MPI-IO case, the "serial" run is completely
> >>>> underestimated by Darshan (the time and bandwidth are less/greater
> >>>> than benchio output).
> >>>> Suggestions are welcomed
> >>>> thanks
> >>>> Piero
> >>>> _______________________________________________
> >>>> Darshan-users mailing list
> >>>> Darshan-users at lists.mcs.anl.gov
> >>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200212/117793ef/attachment-0001.html>
More information about the Darshan-users
