[Darshan-users] error: epstopdf not found in PATH
Latham, Robert J.
robl at mcs.anl.gov
Tue Sep 3 08:51:08 CDT 2019
On Tue, 2019-09-03 at 15:12 +0200, Ayşe Arslan via Darshan-users wrote:
> Dear all,
> I want to use darshan-job-summary.pl utility of Darshan with the
> following code, but I got the error message
> darshan-job-summary.pl ~/Desktop/darshan_files/darshan-3.1.7/darshan-
> test/example-output/mpi-io-test-ppc64-3.0.0.darshan
> I installed epstopdf and followed directions as follows, but the
> error is still same.
http://mirror.las.iastate.edu/tex-archive/macros/latex/contrib/oberdiek/epstopdf.pdf
If you installed from source, I would double-check that the
installation binary directory is in your PATH environment variable.
e.g. if you installed into ${HOME}/soft/texutils then make sure
${HOME}/soft/textutils/bin is also in your path (I will sometimes
slopily forget the 'bin' part myself).
Less likely, your shell has not refreshed its cache of available
binaries. 'hash -r' might do the trick.
==rob
> Do you have any idea about that?
> Thanks
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
