[Darshan-users] dxt_analyzer does not provide the data for all the files used in my simulation
Mahzad Khoshlessan
mahzadkhoshlessan at gmail.com
Fri Jan 25 17:54:29 CST 2019
Hi all,
I am trying to use dxt_analyzer to get the traces and the OSTs assigned to each of my files during my simulations. When I run dxt_analyzer on my darshan log file the I/O trace file get created. However, I noticed that the report is not complete and does not provide the tracing info on all of my files. I have .XTC file which is my main file and all the data needs to be read are included in this file. I have .psf file and .npz file which is a hidden file and contains the offsets for my .XTC file. I am able to see the tracing report for .psf and .npz files, but nothing for .XTC file which is weird. Does any one know why this is the case? Is not it supposed to report the tracing info for all the files?
I set the following parameters in my submit script before I run my code.
export LD_PRELOAD=/home/mkhoshle/installs/darshan/lib/libdarshan.so:/home/mkhoshle/hdf5/v1.10.1/lib/libhdf5.so
#export LD_PRELOAD=/home/mkhoshle/installs/darshan/lib/libdarshan.so
export DARSHAN_LOGPATH=/oasis/scratch/comet/mkhoshle/temp_project/darshan-logs
export SLURM_NODEFILE=`generate_pbs_nodefile`
export DARSHAN_DISABLE_SHARED_REDUCTION=1
export DXT_ENABLE_IO_TRACE=8
Thanks in advance,
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20190125/6fc93f82/attachment-0001.html>
More information about the Darshan-users
