[Darshan-users] darshan3.1.5 issue on Cray XC40 cle6.up05
Phil Carns
carns at mcs.anl.gov
Tue Feb 27 11:03:35 CST 2018
Thanks Bilel. Shane Snyder has been debugging this too and was able to
reproduce the petsc example on a NERSC system. We'll work on getting a
simpler reproducer in our nightly tests and then put out a point release
with a long term fix. In the mean time that manual modification should
be safe.
thanks!
-Phil
On 02/27/2018 11:36 AM, Bilel Hadri wrote:
> Hi Phil,
> Awesome, your workaround fixed the issue.
> Regarding the linker, we are under CLE6Up5, and SUSE12 SP3 on the
> front end node, we are using xalt ( the wrapper to track library usage
> at linking and execution does not conflict with darshan), so the ld
> used is xalt wrapper and it works perfectly with both version.
> which ld
> /sw/xc40cle6/xalt/1.1.2/sles12.3_cce8.6.5/bin/ld
> ld --version
> GNU ld (GNU Binutils) 2.26.0.20160224
> Copyright (C) 2015 Free Software Foundation, Inc.
> This program is free software; you may redistribute it under the terms of
> the GNU General Public License version 3 or (at your option) a later
> version.
> This program has absolutely no warranty.
> I really appreciate your kind and prompt help.
> Regards,
> Bilel
> Bilel Hadri, PhD
> Computational Scientist
> KAUST Supercomputing Lab
> Al Khawarizmi Bldg. (1) Office 126
> 4700 King Abdullah University of Science and Technology
> Thuwal 23955-6900
> Kingdom of Saudi Arabia
> Office Phone: +966 12 808 0654
> Cell Phone: + 966 544 700 893
> *From: *Phil Carns <carns at mcs.anl.gov>
> *Date: *Tuesday, February 27, 2018 at 6:18 PM
> *To: *"bilel.hadri at kaust.edu.sa" <bilel.hadri at kaust.edu.sa>,
> "darshan-users at lists.mcs.anl.gov" <darshan-users at lists.mcs.anl.gov>
> *Subject: *Re: [Darshan-users] darshan3.1.5 issue on Cray XC40 cle6.up05
> On 02/27/2018 12:34 AM, Bilel Hadri wrote:
> Hi Phil,
> Sure, test_scalapack.f90 call ScaLAPACK routines and uses inside
> MPI library. The output of the failing ftn command with the
> craype-verbose flag
> Thanks Bilel. The petsc example helps too. This clarifies that the
> trigger on Cray up05 is to compile a program that doesn't directly
> use MPI symbols on its own but instead links in another library that
> indirectly uses MPI symbols on its behalf.
> This isn't an unusual use case (scalapack and petsc have done this
> forever), and the linker options in Darshan are set up to handle it,
> but something has obviously changed in the linker in this respect in
> this update.
> We are still trying to work out how to reproduce this but it may be a
> little bit. In the mean time would you be willing to try something in
> your 3.1.5 install to help debug?
> Can you manually edit
> /sw/xc40cle6/darshan/3.1.5/sles12.3_gcc7.2.0/share/ld-opts/darshan-base-ld-opts
> and add this line to the top of the file, then try again to compile
> your examples with 3.1.5 loaded?
> --undefined=__wrap_MPI_Init
> By my (admittedly slightly murky) interpretation of the link order and
> the flags that we are setting, that shouldn't be necessary, but it
> would be helpful to see what it does for your example.
> thanks,
> -Phil
> This message and its contents including attachments are intended
> solely for the original recipient. If you are not the intended
> recipient or have received this message in error, please notify me
> immediately and delete this message from your computer system. Any
> unauthorized use or distribution is prohibited. Please consider the
> environment before printing this email.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20180227/71449eb8/attachment.html>
More information about the Darshan-users
