[Darshan-users] darshan-parser output in json format
Shane Snyder ssnyder at mcs.anl.gov
Wed Aug 22 12:55:16 CDT 2018
Hi George,
Adding to Kevin's comment -- we have found the ability to extract
Darshan parser output in JSON format to be valuable in a couple of other
external projects too, but it is not currently on any development
roadmap for integration into Darshan proper. It is something we can
consider in the future though, especially since we are working on other
features that will probably make this easier (namely, implementing a
Python interface to the darshan-utils library).
If it's useful in the meantime, I can point you at code from one of our
projects (TOKIO) that implements a JSON parser for Darshan logs. TOKIO
is a broader project concerned with holistic I/O analysis of HPC
systems, and as part of it we have implemented a number of different
Python tools for analyzing different I/O logs (including Darshan), all
in the pytokio repo: https://github.com/NERSC/pytokio.
'bin/cache_darshan.py' is the script that can take a Darshan log file
and spit out JSON data for all of the counters, metadata, etc.
--Shane
On 08/21/2018 06:16 PM, George Papadimitriou wrote:
> Hi Kevin,
> This is what we are currently doing. But I've found that parsing the
> ascii output can be a bit tedious and not an elegant solution to the
> problem.
> George
> *From:* Harms, Kevin <harms at alcf.anl.gov>
> *Sent:* Tuesday, August 21, 2018 3:52:31 PM
> *To:* George Papadimitriou; darshan-users at lists.mcs.anl.gov
> *Subject:* Re: darshan-parser output in json format
>   I don't think we have a plan for it right now. I think the easiest
> method would be to take the ASCII output and convert it to JSON using
> a separate tool.
> kevin
> From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on
> behalf of George Papadimitriou <georgpap at isi.edu>
> Sent: Tuesday, August 21, 2018 12:13:42 PM
> To: darshan-users at lists.mcs.anl.gov
> Subject: [Darshan-users] darshan-parser output in json format
> Hello,
> I'm aware of an open ticket
> (https://xgitlab.cels.anl.gov/darshan/darshan/issues/242) about having
> an option in darshan-parser to enable json output.
> Is this feature on darshan-parser's roadmap ?
> Thanks,
> George
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20180822/edf2e519/attachment.html>
More information about the Darshan-users mailing list
