[Darshan-users] Darshan not creating trace file and not complaining
Shane Snyder
ssnyder at mcs.anl.gov
Tue Oct 31 11:40:16 CDT 2017
Assuming users have no issues with the pre-release, this workaround will
be generally available starting in Darshan 3.1.5, which we can probably
release officially within the next few weeks.
--Shane
On 10/31/2017 11:35 AM, Shane Snyder wrote:
> Hi Wadud,
> It looks like you are trying to run one of the NAS benchmark codes,
> which I believe are Fortran programs, right?
> This is due to a known "issue" with OpenMPI2 where the Fortran
> bindings are calling PMPI_ routines directly, bypassing Darshan's use
> of the MPI profiling interface (PMPI). Basically, Darshan is unable to
> intercept any MPI calls, including MPI_Init/Finalize which is where
> Darshan initializes its data structures and does the generation of the
> log file, respectively. No error is generated for the same reason:
> Darshan never initializes itself and doesn't think it should be
> instrumenting anything. If interested in more details, check out this
> github issue: https://github.com/open-mpi/ompi/issues/3954
> Ignoring the philosophical question of whether the "issue" here lies
> with the MPI implementation or tools that use the MPI profiling
> interface (this issue affects all PMPI tools, not just Darshan), we've
> actually spent some time developing a workaround for this issue
> recently, so you are in luck!
> I have not gone through with making a pre-release version of Darshan
> with this workaround publicly available, though I really have been
> meaning to. I will definitely make sure to do that today, and will
> send an update to this mailing list when its ready so you (and others)
> are aware. So, you have a couple of options:
> 1.) Wait for that pre-release to come out later this afternoon, or
> 2.) Check out the master branch of the Darshan git repo
> (https://xgitlab.cels.anl.gov/darshan/darshan)
> Either should resolve the issue, but be sure to let us know if not.
> Thanks,
> --Shane
> On 10/31/2017 10:51 AM, Wadud Miah wrote:
>> Hi everyone,
>> I built Darshan 3.1.4 with OpenMPI 2.0.2 and gcc 7.2.1 using the
>> following configure flags:
>> ./configure --with-mem-align=8 --with-log-path-by-env=DARSHAN_LOGPATH
>> --with-jobid-env=NONE CC=mpicc --prefix=/usr/local/darshan-3.1.4-ompi
>> I have also attached the config.log file. When I run my application
>> with LD_PRELOAD, Darshan does not create any trace file and neither
>> does it complain:
>> [miahw at bedale bin]$ export DARSHAN_LOGPATH=.
>> LD_PRELOAD=/usr/local/darshan-3.1.4-ompi/lib/libdarshan.so mpirun -n
>> 4 ./bt.A.4.mpi_io_full
>> [ ... lots of application output ... ]
>> [miahw at bedale bin]$ ls
>> bt.A.4 bt.A.4.mpi_io_full btio.full.out inputbt.data
>> As you can see, there is no trace file in the current working
>> directory. Any help will be greatly appreciated.
>> Thanks in advance,
>> Wadud.
>> Dr. Wadud Miah
>> Numerical Algorithms Group
>> *Disclaimer*
>> The Numerical Algorithms Group Ltd is a company registered in England
>> and Wales with company number 1249803. The registered office is:
>> Wilkinson House, Jordan Hill Road, Oxford OX2 8DR, United Kingdom.
>> This e-mail has been scanned for all viruses and malware, and may
>> have been automatically archived by Mimecast Ltd, an innovator in
>> Software as a Service (SaaS) for business.
>> Darshan-users mailing list
>> Darshan-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20171031/92cf0d7a/attachment-0001.html>
More information about the Darshan-users
