[Darshan-users] undefined reference to __wrap_printf
Shane Snyder ssnyder at mcs.anl.gov
Thu Jul 20 16:35:07 CDT 2017
On 07/20/2017 04:19 PM, Shane Snyder wrote:
> Hi Teng,
> First of all, I actually just got darshan 3.1.4 to properly generate a
> log when using static linking. I'm not sure what was leading to the
> problem I had earlier, but after reconfiguring and rebuilding the
> library, it works for me now. I also confirmed the nightly tests were
> working correctly -- the log files were going to another spot that I
> wasn't expecting, so missed them the first time around. You may want
> to try something similar -- just rebuilding everything from scratch
> and trying again. I've also run into this problem in the past whenever
> I was accidentally pointing to an mpich build that defaults to using
> shared libraries rather than the static ones, so that could be another
> thing to check.
> As for the error you are getting with Darshan 3.1.3, I've actually
> never seen someone hit that before. That error would be due to the
> libz compression functions (deflate) returning some sort of error. Not
> exactly sure what could cause that, but is the application opening a
> really large amount of files or something like that? I suppose it's
> possible the compression routines could be running out of memory if
> there is too much log data they are trying to compress, but have never
> seen that happen before. If you aren't already, it might be worth
> trying a test program that does very basic I/O just to confirm that we
> can get Darshan working. One that we frequently use is mpi-io-test --
> there is a version of this code in the darshan source @
> darshan-test/regression/test-cases/src. You could try just building
> that and running it (it doesn't take any command line parameters) to
> see if that works?
Oh, actually I just noticed in your emails that you were using
mpi-io-test? That is pretty bizarre...
What system are you running this on? A cluster? Your own personal
machine? If possible, you might try running somewhere else so we can
confirm the issue is some problem with the environment on the system you
have been using... I can't think of why the deflate routines would fail
when running something simple like mpi-io-test. But if needed, we could
probably get you a patch or something that tries to give us more details
on the libz error you are seeing.
--Shane
> Thanks,
> --Shane
> On 07/20/2017 03:52 PM, Teng Wang wrote:
>> Hi Shane,
>> Thanks for your help on this. I tried v3.1.3 and compiled successfully.
>> But when I ran the application, there was no *.log generated under the
>> log directory, and I also got a warning from the application:
>> darshan library warning: unable to compress job data
>> May I know how to fix this?
>> Thanks,
>> Teng
>> On Thu, Jul 20, 2017 at 11:51 AM, Shane Snyder <ssnyder at mcs.anl.gov
>> <mailto:ssnyder at mcs.anl.gov>> wrote:
>>     Hi Teng,
>>     Thanks for reporting this. This is a really strange issue, but I
>>     can actually reproduce it, too. I'm going to keep digging and see
>>     if I can find the problem. Will keep you updated.
>>     The strange thing is that I was able to use version 3.1.4
>>     successfully right before making the release available (i.e., the
>>     log @
>>     darshan-test/example-output/mpi-io-test-x86_64-3.1.4.darshan was
>>     generated using version 3.1.4 with static linking). Also strange
>>     is that our nightly testing is not catching this issue...
>>     FYI, version 3.1.3 and earlier work fine for me if you really
>>     need a quick resolution -- version 3.1.4 just fixed a couple of
>>     non-critical bugs in some darshan log parsing utilities, so there
>>     shouldn't be much functionally different between the versions.
>>     --Shane
>>     On 07/20/2017 12:43 PM, Teng Wang wrote:
>>>     Hi,
>>>     I'm having trouble when trying to statically link
>>>     Darshan with mpich3.3 applications following the instructions
>>>     here. Could you give me any suggestion on how to fix it?
>>>     http://www.mcs.anl.gov/research/projects/darshan/docs/darshan-runtime.html
>>>     <http://www.mcs.anl.gov/research/projects/darshan/docs/darshan-runtime.html>
>>>     Here is my steps:
>>>     1. Compile and install darshan 3.1.4
>>>     tar -xvzf darshan-3.1.4.tar.gz
>>>     cd darshan-3.1.4/darshan-runtime
>>>     ./configure --with-mem-align=8 --with-log-path=<log directory>
>>>     --prefix=<install directory> --with-jobid-env=PBS_JOBID
>>>     --disable-cuserid CC=mpicc
>>>     make
>>>     make install
>>>     2. Create log directory, which successfully create the directory
>>>     darshan-mk-log-dirs.pl <http://darshan-mk-log-dirs.pl/>
>>>     3. Generate wrapper
>>>     darshan-gen-cc.pl <http://darshan-gen-cc.pl/> `which mpicc`
>>>     --output mpicc.darshan
>>>     4. Compile application (mpi-io-test.c) using mpicc.darshan
>>>     mpicc.darshan mpi-io-test.c -o mpi-io-test
>>>     After step 4, the following issue happened:
>>>     initthread.c:(.text+0xc59d): undefined reference to `__wrap_fprintf'
>>>     initthread.c:(.text+0xc5bd): undefined reference to `__wrap_fputs'
>>>     /global/homes/t/user/software_install/mpich3.3a-static/lib/libmpi.a(lib_libmpi_la-finalize.o):
>>>     In function `MPIR_Add_finalize':
>>>     finalize.c:(.text+0x226e): undefined reference to `__wrap_fputs'
>>>     finalize.c:(.text+0x227a): undefined reference to `__wrap_fflush'
>>>     finalize.c:(.text+0x2286): undefined reference to `__wrap_fflush'
>>>     /global/homes/t/user/software_install/mpich3.3a-static/lib/libmpi.a(lib_libmpi_la-util.o):
>>>     In function `MPIDI_OFI_control_handler':
>>>     util.c:(.text+0x17bc4): undefined reference to `__wrap_fprintf'
>>>     /global/homes/t/user/software_install/mpich3.3a-static/lib/libmpi.a(lib_libmpi_la-ch4_globals.o):
>>>     In function `MPID_Abort':
>>>     ch4_globals.c:(.text+0x38b): undefined reference to `__wrap_fputs'
>>>     ch4_globals.c:(.text+0x397): undefined reference to `__wrap_fflush'
>>>     ch4_globals.c:(.text+0x3a3): undefined reference to `__wrap_fflush'
>>>     /tmp/ccyntLoA.o: In function `main':
>>>     mpi-io-test.c:(.text+0x5ae): undefined reference to `__wrap_printf'
>>>     mpi-io-test.c:(.text+0x819): undefined reference to `__wrap_printf'
>>>     /global/homes/t/user/software_install/mpich3.3a-static/lib/libmpi.a(lib_libmpi_la-contextid.o):
>>>     In function `MPIR_Free_contextid':
>>>     contextid.c:(.text+0x1c3f): undefined reference to `__wrap_fputs'
>>>     contextid.c:(.text+0x1c4b): undefined reference to `__wrap_fflush'
>>>     contextid.c:(.text+0x1c57): undefined reference to `__wrap_fflush'
>>>     mpicc.darshan -show mpi-io-test.c -o mpi-io-test gave:
>>>     gcc -L/usr/lib64/slurmpmi
>>>     -L/global/common/cori/software/libfabric/1.4.1/gnu/lib
>>>     -L/global/homes/t/user/software_install/darshan/lib -ldarshan
>>>     -lz
>>>     -Wl,@/global/homes/t/user/software_install/darshan/share/ld-opts/darshan-base-ld-opts
>>>     -I/global/homes/t/user/software_install/mpich3.3a-static/include
>>>     -L/global/homes/t/user/software_install/mpich3.3a-static/lib
>>>     -lmpi -lpmi -lpmi -lpthread -lfabric -lrt -lpmi
>>>     -Wl,--start-group -ldarshan -ldarshan-stubs -Wl,--end-group -lz
>>>     -lrt -lpthread
>>>     The strange thing is when I do
>>>     nm libdarshan.a, it did show the functions (e.g. __wrap_printf)
>>>     were linked to
>>>     libdarshan.a.
>>>     *0000000000002bf0 T __wrap__IO_getc*
>>>     *0000000000002d80 T __wrap__IO_putc*
>>>     *00000000000030b0 T __wrap___isoc99_fscanf*
>>>     *0000000000001990 T __wrap_fclose*
>>>     *00000000000011d0 T __wrap_fdopen*
>>>     *0000000000001810 T __wrap_fflush*
>>>     *0000000000002a60 T __wrap_fgetc*
>>>     *0000000000003690 T __wrap_fgets*
>>>     *0000000000000db0 T __wrap_fopen*
>>>     *0000000000000fc0 T __wrap_fopen64*
>>>     *00000000000026b0 T __wrap_fprintf*
>>>     *0000000000001c80 T __wrap_fputc*
>>>     *0000000000001fa0 T __wrap_fputs*
>>>     *00000000000028d0 T __wrap_fread*
>>>     *00000000000013d0 T __wrap_freopen*
>>>     *00000000000015f0 T __wrap_freopen64*
>>>     *00000000000032d0 T __wrap_fscanf*
>>>     *0000000000003920 T __wrap_fseek*
>>>     *0000000000003a30 T __wrap_fseeko*
>>>     *0000000000003b40 T __wrap_fseeko64*
>>>     *0000000000003c50 T __wrap_fsetpos*
>>>     Thanks,
>>>     Teng
>>>     _______________________________________________
>>>     Darshan-users mailing list
>>>     Darshan-users at lists.mcs.anl.gov
>>>     <mailto:Darshan-users at lists.mcs.anl.gov>
>>>     https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
>>>     <https://lists.mcs.anl.gov/mailman/listinfo/darshan-users>
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20170720/2a439ca8/attachment-0001.html>
More information about the Darshan-users mailing list
