[Darshan-users] compatibility with HDF5 1.10.x
    Phil Carns
    carns at mcs.anl.gov
    Mon Jan 30 15:54:53 CST 2017
Just a quick update on this.  The master branch in git now includes
Kalle's patch, plus a corresponding option to explicitly enable support
for the older API version instead.  That will make it possible to enable
either one and control conflicts using a higher level construct (e.g.,
software module dependencies) or to disable the hdf5 module on systems
where that's difficult to do.  This will be in the upcoming 3.1.3 release.
thanks,
-Phil
On 01/17/2017 03:34 PM, Phil Carns wrote:
> That's bad news :(
> That means that we might get the wrapper prototypes wrong at link time
> no matter how you compile Darshan.  The user could always load or link
> to a different version of HDF5. There won't be any link time warning.
> We can probably query the HDF library at runtime to find out what
> version it is within the H5 open() wrappers, but even so, the only
> thing we could do if we detected a mismatch would be to error out and
> print "Please recompile darshan, this version is not binary ABI
> compatible with HDF API FOO". I can't think of any way to silently
> recover or even proceed without instrumentation.  By the time we
> detect the mismatch we will have already jumbled the arguments.
> We could also try to make software module conflicts (so that if you
> module load a newer version of HDF it automatically swaps the Darshan
> module or disables it), but that's not very clean either.
> Does anyone on the list have an idea for how to handle this more
> transparently?
> -Phil
> On 01/17/2017 02:38 PM, Rob Latham wrote:
>> On 01/16/2017 02:26 PM, Phil Carns wrote:
>>> Hi Kalle,
>>> Sorry for the delay, just now catching up on this and doing some
>>> testing
>>> so we can apply the patch.
>>> What kind of system did you trigger the problem on?  It seems like int
>>> and int64_t should be interchangeable (lucky for us) on most
>>> systems, so
>>> I'm trying to figure out what the regression test would be.
>> As someone who not that long ago promoted  out all the 'ints' in
>> MPICH to "int64_t' (or its equivalent), the two are *not*
>> interchangeable.
>>  int is 32 bits on every common platform, and int64_t is, well, 64 bits.
>> Longs and Pointers are 64 bits on x86_64
>> ==rob
>>> thanks,
>>> -Phil
>>> On 11/15/2016 10:41 AM, Phil Carns wrote:
>>>> Thank you very much for the patch, Kalle!
>>>> The team is pretty busy this week with SC16 activities, but we will
>>>> have a look at your patch soon.  Thanks for catching that.
>>>> I agree that it would be great if we could have one Darshan build that
>>>> works with both versions of the HDF API, but I don't see a way to do
>>>> it either...
>>>> -Phil
>>>> On 11/13/2016 11:21 AM, Karl-Ulrich Bamberg wrote:
>>>>> Dear Darshan-developers,
>>>>> Thanks for this great tool, it helps us a lot.
>>>>> We switched to HDF5 1.10 and found that DARSHAN (Git/master) is not
>>>>> compatible due to the typedef of hid_t which changed in HDF5 1.10.
>>>>> There is a patch attached, that provides a configure-switch for HDF5
>>>>> 1.10.
>>>>> Unfortunately 1.10 breaks compatibility tim 1.8 so I do not (yet)
>>>>> see, if there is any way to use both with the same DARSHAN.
>>>>> Kind regards and keep up with the good work :-)
>>>>> Kalle
>>>>> Mit freundlichen Grüßen
>>>>> Karl-Ulrich Bamberg
>>>>> Ludwig-Maximilians-Universität München
>>>>> Arnold-Sommerfeld-Center (ASC)
>>>>> Computational & Plasma Physics
>>>>> Theresienstr. 37, D-80333 München
>>>>> phone: +49 (0)89 2180 4577
>>>>> fax: +49 (0)89 2180 99 4577
>>>>> e-mail: Karl-Ulrich.Bamberg at physik.uni-muenchen.de
>>>>> <mailto:Karl-Ulrich.Bamberg at physik.uni-muenchen.de>
>>>> _______________________________________________
>>>> Darshan-users mailing list
>>>> Darshan-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
