[Darshan-users] compatibility with HDF5 1.10.x
    Phil Carns
    carns at mcs.anl.gov
    Mon Jan 16 14:26:00 CST 2017
Hi Kalle,
Sorry for the delay, just now catching up on this and doing some testing
so we can apply the patch.
What kind of system did you trigger the problem on?  It seems like int
and int64_t should be interchangeable (lucky for us) on most systems, so
I'm trying to figure out what the regression test would be.
thanks,
-Phil
On 11/15/2016 10:41 AM, Phil Carns wrote:
> Thank you very much for the patch, Kalle!
> The team is pretty busy this week with SC16 activities, but we will
> have a look at your patch soon.  Thanks for catching that.
> I agree that it would be great if we could have one Darshan build that
> works with both versions of the HDF API, but I don't see a way to do
> it either...
> -Phil
> On 11/13/2016 11:21 AM, Karl-Ulrich Bamberg wrote:
>> Dear Darshan-developers,
>> Thanks for this great tool, it helps us a lot.
>> We switched to HDF5 1.10 and found that DARSHAN (Git/master) is not
>> compatible due to the typedef of hid_t which changed in HDF5 1.10.
>> There is a patch attached, that provides a configure-switch for HDF5
>> 1.10.
>> Unfortunately 1.10 breaks compatibility tim 1.8 so I do not (yet)
>> see, if there is any way to use both with the same DARSHAN.
>> Kind regards and keep up with the good work :-)
>> Kalle
>> Mit freundlichen Grüßen
>> Karl-Ulrich Bamberg
>> Ludwig-Maximilians-Universität München
>> Arnold-Sommerfeld-Center (ASC)
>> Computational & Plasma Physics
>> Theresienstr. 37, D-80333 München
>> phone: +49 (0)89 2180 4577
>> fax: +49 (0)89 2180 99 4577
>> e-mail: Karl-Ulrich.Bamberg at physik.uni-muenchen.de
>> <mailto:Karl-Ulrich.Bamberg at physik.uni-muenchen.de>
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20170116/1525b12f/attachment.html>
More information about the Darshan-users
