[Darshan-users] Darshan 3.1.3 official release is now available
Shane Snyder
ssnyder at mcs.anl.gov
Mon Feb 13 08:33:08 CST 2017
Darshan-users,
The official release for Darshan version 3.1.3 is now available for
download here
<ftp://ftp.mcs.anl.gov/pub/darshan/releases/darshan-3.1.3.tar.gz>. We
have tested this release extensively and believe it is stable and ready
for use in production. On top of the numerous new features and bug fixes
included in the darshan-3.1.3-pre1 release (listed in the original email
copied below), the official version has one additional bug fix:
* Instrumentation of mmap calls is now disabled for dynamically linked
applications (i.e., applications that LD_PRELOAD darshan)
- this avoids potential deadlock issues on Cray systems when using
dynamically linked executables (reported by Cristian Simarro)
You can find updated documentation for darshan-runtime and darshan-util
components here
<http://www.mcs.anl.gov/research/projects/darshan/documentation/>.
Please let us know if you have any questions, issues, or concerns using
this mailing list, or by opening an issue on the Darshan GitLab page
<https://xgitlab.cels.anl.gov/darshan/darshan>.
--Darshan team
On 01/31/2017 01:44 PM, Shane Snyder wrote:
> Darshan users,
> A new Darshan pre-release (3.1.3-pre1) is now available for download
> here
> <ftp://ftp.mcs.anl.gov/pub/darshan/releases/darshan-3.1.3-pre1.tar.gz>.
> Please be aware that this pre-release is experimental and *not*
> recommended for full-time use in production yet. We hope to have the
> official 3.1.3 release ready some time next week.
> Here is the list of new features and bug fixes in this release:
> * New DxT (Darshan eXtended Tracing) instrumentation modules that
> provide fine-grained tracing data of read/write operations at the
> POSIX & MPI-IO layers
> - This tracing module is not enabled by default, and it is
> envisioned that it be enabled selectively at runtime for applications
> of interest
> - This code was contributed by Cong Xu and Intel's High
> Performance Data Division (HPDD)
> * Darshan now captures command line arguments for Fortran applications
> - This fix was contributed by Cristian Simarro
> * Fix potential deadlock when using the Cray hugepages module and Darshan
> - Reported by Glenn Lockwood & Cristian Simarro
> * Fix potential segmentation fault when Darshan exceeds the maximum
> number of tracked access sizes/strides
> * Disable Darshan's HDF5 module by default to avoid potential ABI
> compatibility issues with HDF5
> - New configure switches are provided to enable Darshan support
> for specific HDF5 library versions
> - Problem report and initial patch provided by Karl-Ulrich Bamberg
> * Add whitelist to Darshan's list of file path exclusions to prevent
> I/O to/from Cray's Datawarp service from being filtered out
> - Contributed by Glenn Lockwood
> Updated documentation related to using the DxT tracing modules can be
> found in the source tree ('darshan-runtime/docs' for the Darshan
> runtime library & darshan-util/docs for Darshan's utilities). To
> summarize, DxT tracing can be enabled at runtime by exporting the
> 'DXT_ENABLE_IO_TRACE' environment variable. DxT also has a
> corresponding parser utility named 'darshan-dxt-parser' that can be
> used to parse trace data out of Darshan log files.
> As always, let us know if you have any questions, issues, or concerns
> using this mailing list, or by opening an issue on the Darshan GitLab
> page <https://xgitlab.cels.anl.gov/darshan/darshan>.
> Thanks!
> --Darshan team
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20170213/e925d7bb/attachment.html>
More information about the Darshan-users
