[Darshan-users] Bad data in file headers
Phil Carns
carns at mcs.anl.gov
Sun Dec 3 20:11:11 CST 2017
Thanks for the follow up details, Ed. Sounds like it might be time to
investigate what that app is up to :)
-Phil
On 12/02/2017 10:39 AM, Ed Karrels wrote:
> On Fri, 2017-12-01 at 11:24 -0500, Phil Carns wrote:
> > Hi Ed,
> > I don't think we've seen this particular error before. Is it also
> > the same application/executable every time in addition to being the
> > same user in each case?
> Yep, same application, "pcp". Not sure why I missed these cases
> before, but there are other users running this application, and each
> of their darshan3 files have the same errors. So it seems to be the
> application, not the user.
> Rob Latham:
> > Is there any chance darshan2 tools are trying to operate on darshan3
> > files? I hate to offer such an obvious suggestion, but you have
> > generated both log formats so at some point in time you had darshan2
> > tooling lying around. Any darshan2 libraries or tools are probably
> > long gone by now but I wanted to rule out the obvious.
> I don't think so. All the darshan2 files have ".darshan.gz" as their
> filename suffix and the first few bytes are a gzip header: 1F 8B 08 00
> These files have ".darshan" as their filename suffix, and the header
> starts with "3.10".
> $ head -c 64
> logtree/00/2f/heitz_pcp_id7666317_10-15-53224-12998966924006311962_1.darshan
> | hexdump
> 000000: 33 2E 31 30 00 00 00 00 37 35 64 00 00 00 00 00 3.10....75d.....
> 000010: 00 00 00 00 00 00 00 00 FB 01 00 00 00 00 00 00 ................
> 000020: 05 FE FF FF FF FF FF FF 00 00 00 00 00 00 00 00 ................
> 000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20171203/cfd00622/attachment.html>
More information about the Darshan-users
