[Darshan-users] Bad data in file headers
Phil Carns
carns at mcs.anl.gov
Fri Dec 1 10:24:01 CST 2017
Hi Ed,
I don't think we've seen this particular error before. Is it also the
same application/executable every time in addition to being the same
user in each case?
That portion of the log file is the index that tells the parser library
where to find data for each of the instrumentation modules. Every
Darshan log uses that index, so it would be unusual (but of course not
impossible by any means!) for it to be broken. It is deterministically
malloc'd at the same point in time when Darshan is initialized:
https://xgitlab.cels.anl.gov/darshan/darshan/blob/master/darshan-runtime/lib/darshan-core.c#L245
If it is the same executable triggering the problem in each case, then I
would be suspicious of a stack overflow or some other memory corruption
in the application that just happens to cause collateral damage in the
address range that this malloc is getting.
Unfortunately that's the kind of thing that's hard to isolate after the
fact, though; all we know for sure is that the log is broken. If you
have access to the source code it sounds like it might be pretty
reproducable at run time, though.
thanks,
-Phil
On 11/29/2017 12:14 PM, Ed Karrels wrote:
> I'm scanning through Darshan logs from Blue Waters, and darshan-parser
> fails on bunch (1588) of log files. They're all Darshan version 3
> files, and all from the same user. Every one of this user's Darshan
> version 3 files fails. Their Darshan version 2 files are fine.
> I ran darshan-parser in a debugger, and found that the headers seem to
> have a couple garbage entries.
> After the call to darshan_log_get_job(), the "len" fields in
> fd->name_map and fd->mod_map[6] seem to be invalid:
> (gdb) p /x fd->name_map
> $42 = {off = 0x1fc, len = 0xfffffffffffffe04}
> (gdb) p /x fd->mod_map[6]
> $43 = {off = 0x277, len = 0xfffffffffffffd89}
> Have you seen errors like these before? Any idea why they're
> happening? Since it's only one user, I suspect it's something in
> their code, perhaps a failure during MPI_Finalize.
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20171201/f7ef6ae8/attachment.html>
More information about the Darshan-users
