[Darshan-users] darshan 3.0.0 official release
    Shane Snyder
    ssnyder at mcs.anl.gov
    Mon Mar 28 16:22:28 CDT 2016
Darshan users,
Darshan 3.0.0, the new modularized implementation of Darshan, is now
officially ready to be released! This is the first stable release of the
Darshan 3.0 fork and builds off the experimental pre-releases we have
been providing over the last few months.  We encourage users to consider
upgrading to this version in the near future as it contains numerous
enhancements over older versions: logging of full file paths, clearer
parser and job summary output, addition of a BG/Q specific
instrumentation module, future proofing for any upcoming instrumentation
modules, etc.
The following changes have been made between this official release and
the last pre-release (darshan-3.0.0-pre3):
* fix bug causing compile errors when building external utilities that
use the darshan-util API/library
* update docs to give debugging tips for cases where Darshan logs are
not generated
* update darshan-runtime docs to give information on upgrading Darshan
* fix shared library regression test script to check for potential
errors with Darshan symbols rather than failing silently in these cases
* bug fix for determining minimum non-zero counters in shared file
reductions in all modules
* loosen Darshan’s PMPI symbol check to prevent inadvertent disabling of
Darshan for some MPICH builds
* bug fix for resolving MPI_Gather and MPI_Barrier when LDPRELOADing
Darshan’s shared libraries
* add more helpful error handling when opening 2.x version log files
* port darshan-diff utility over to new 3.0.0 log file format
* fix numerous configure bugs on Cray systems
* add synthetic benchmarking hooks for testing Darshan’s shutdown procedure
We have tested this version extensively on a number of platforms over
the last few months and are satisfied with the new features and
Darshan’s overall performance. Included in the darshan-runtime
documentation (a link is provided below) is some information on how to
best upgrade from a Darshan 2.x version to Darshan 3.0.0. As always,
please let us know if you have any issues or questions (using either the
Darshan users mailing list or by opening an issue on the Darshan GitLab
page).
You can download the release tarball HERE
<http://press3.mcs.anl.gov/darshan/download/>.
Documentation for this version of Darshan can be found HERE
<http://press3.mcs.anl.gov/darshan/documentation/>.
Thanks!
--Darshan team
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20160328/57e2486a/attachment.html>
More information about the Darshan-users
