[Darshan-users] Estimating the overlap of MPI I/O wait time
Harms, Kevin
harms at alcf.anl.gov
Wed Feb 3 11:36:08 CST 2016
Jean-Thomas,
your analysis is correct. Given that the data collected is statistical, one must make some assumptions about the I/O to estimate performance. If you use, darshan-parser --perf <logfile>, this will print some estimates using different heuristics. If you have any feedback on the accuracy, let us know.
kevin
>Hi,
>I'm using Darshan to analyze the behavior of a parallel MPI Fortran application which writes to a shared file. Among 1024 MPI ranks only 48 are effectively doing I/O, this "geometry" is successfully reported by Darshan.
>However, for the remaining 48 ranks Darshan reports the MPI I/O time spent writing to the shared file on a per rank basis, but I did not find a way to estimate the overlap between these different ranks.
>At one end of the spectrum, if write accesses are serialized then the total I/O wait time for the application is the sum of the individual wait time of each rank.
>On the other end, if write accesses are perfectly parallel the total app wait time is the max among the 48 writers.
>Probably the exact number lies between these two values, is there a way to estimate it ?
>Best regards,
> jean-thomas
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20160203/550c5022/attachment.bin>
More information about the Darshan-users
