[Darshan-users] Different builds for each MPI/compiler
Phil Carns
carns at mcs.anl.gov
Wed Sep 9 12:38:04 CDT 2015
On 09/09/2015 10:55 AM, Chih-Song Kuo wrote:
> *Von:*darshan-users-bounces at lists.mcs.anl.gov
> [mailto:darshan-users-bounces at lists.mcs.anl.gov] *Im Auftrag von *Phil
> Carns
> *Gesendet:* Mittwoch, 9. September 2015 15:52
> *An:* darshan-users at lists.mcs.anl.gov
> *Betreff:* Re: [Darshan-users] Different builds for each MPI/compiler
> On 09/09/2015 06:55 AM, Chih-Song Kuo wrote:
> Hello Darshan user community,
> I just started using Darshan. Despite it runs pretty well, I
> wonder if I have to create different builds for each combination
> of MPI and compiler. I had this concern because you wrote some
> issues about libfmpich.so. I as a sales consultant of an
> HPC-system vendor run benchmarks with many combinations of MPI and
> compilers to advise our customer the best choice.
> Your insight will be greatly appreciated.
> Chih-Song
> Hi Chih-Song,
> I have two pieces of information that might be helpful:
> a) The underlying compiler generally doesn't matter as much as the MPI
> library itself. We usually compile Darshan itself with GNU compilers
> for maximum compatibility; the resulting Darshan library should be
> compatible with most any compiler/linker.
> b) As for the MPI library, the MPICH ABI compatibility initiative
> (https://www.mpich.org/abi/) should help in theory by making sure that
> quite a few of the MPI implementations have a compatible binary
> interface. Our team hasn't tested this capability first hand, so I
> can't guarantee it will work, but I think the prospects are good.
> thanks,
> -Phil
> Hi Phil,
> Thanks. It looks like I might be worrying too much. According my
> experience with IPM’s I/O profiling module, different MPIs seem to
> have some difference in the appearance of the “const” modifier which
> caused some trouble in the compilation.
This would mainly be an issue for mixing MPI 2 and MPI 3 implementations
(const correctness is part of the latter spec). I imagine there would
be more significant roadblocks to that level of interoperability
though. It's probably best to at least stick to one major version or
the other for a given Darshan build.
FWIW Darshan does detect the const issue at compile time (for the
Darshan library itself), so you can build a version of Darshan for use
with either API generation.
> Also, on
> https://www.nersc.gov/users/software/debugging-and-profiling/ipm/,
> there seems to be some module explicitly built for Intel compilers. I
> thought Darshan uses a similar profiling technique, so I was asking.
I don't believe this is the case. Darshan's various instrumentation
methods (link-time wrappers, PMPI, or preloading) are all
compiler-independent to my knowledge. IPM captures more in-depth
information so it may rely on additional methods.
> I read in some Darshan research papers that the tool has been enabled
> by default on several NERSC clusters. Do the users there have a wide
> choice of MPI implementations? Do you have any clue which MPIs are
> chosen by the user and also get successfully profiled by Darshan?
I don't have that information myself, sorry. I know that Darshan works
with each of the compilers that are available (and users do switch those
for various reasons), but I'm not sure about the MPI implementations.
thanks,
-Phil
> Cheers,
> Chh-Song
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150909/17de921b/attachment.html>
More information about the Darshan-users
