[Darshan-users] LD_PRELOAD system() call
    Phil Carns
    carns at mcs.anl.gov
    Wed May  6 15:47:22 CDT 2015
Hi Cristian,
Here are the results from an execution on Edison, with that fprintf
added just before the existing one.  I think line 260 is probably the
last valid line before the hang (the rest are messages printed after the
scheduler starts trying to kill the job).
thanks,
-Phil
On 05/06/2015 02:33 PM, Phil Carns wrote:
> On 05/05/2015 07:09 AM, Cristian Simarro wrote:
>> Hi Phill,
>> I have tried your test in our Cray but I can not reproduce the
>> behaviour. Actually the test program is finishing properly.
> Interesting!  I assume it is printing output showing that the wrappers
> were triggered, though, right?
> I'm attaching my job script just in case there is any difference there
> in how we are executing the test case.  I think I probably compiled
> the example program with Intel compilers, while the read-wrapper
> library was compiled with GNU, though I wouldn't think that part would
> matter here.  The system is running craype 2.2.1.
>> Can you add traceback information about the call?
>>           Dl_info dli;
>>      original_read = dlsym(RTLD_NEXT, "read");
>>      dladdr(original_read,&dli);
>>      fprintf(stderr, "debug trace [%d]: %s "
>>                      "called by %p [ %s(%p) %s(%p) ].\n",
>>                      getpid(), __func__,
>>                       __builtin_return_address(0),
>>                      strrchr(dli.dli_fname, '/') ?
>>                              strrchr(dli.dli_fname, '/')+1 :
>> dli.dli_fname,
>>                      dli.dli_fbase, dli.dli_sname, dli.dli_saddr);
> Sure, I'll give that a try and report back.  Thanks for the example; I
> was thinking that a backtrace might be very helpful but I wasn't sure
> how to best go about collecting it :)
> thanks,
> -Phil
>> Best regards,
>> Cristian
>> Cristian Simarro
>> Analyst, User Support Section
>> European Centre for Medium-Range Weather Forecasts (ECMWF)
>> Shinfield Park, Reading, RG2 9AX, United Kingdom
>> Tel:    (+44 118) 9499315                Fax:    (+44 118) 9869450
>> E-mail: Cristian.Simarro at ecmwf.int http://www.ecmwf.int
>> ----- Original Message -----
>> From: "Phil Carns" <carns at mcs.anl.gov>
>> To: darshan-users at lists.mcs.anl.gov
>> Sent: Sunday, 3 May, 2015 3:35:46 PM
>> Subject: Re: [Darshan-users] LD_PRELOAD system() call
>> Hi Cristian,
>> This is definitely the same problem that Kalyana and I were looking at
>> earlier with fork().  I built a very small example reproducer library to
>> try to simplify the problem (see Makefile and read-wrapper.c). The
>> read-wrapper.c isn't doing anything except intercepting the read()
>> function, printing some information, then calling the real read()
>> function.  I've been building this library with PrgEnv-gnu.
>> The test.c is your example program, and the
>> test-preload-read-wrapper.pbs.e* is an example stderr file from trying
>> to run it with the example read wrapper library preloaded.
>> There isn't any Darshan code involved here, but the example still
>> hangs.  It looks like you could trigger it with *any* wrapper on the
>> read() function in the Cray environment in conjunction with a fork() or
>> system() call.  Maybe there is some sort of recursion here?
>> I'll keep thinking about this some, but I thought I would share what I'm
>> seeing with the list in case anyone else has an idea.
>> thanks,
>> -Phil
>> On 05/01/2015 12:06 PM, Carns, Philip H. wrote:
>>> Hi Cristian,
>>> I was testing on Edison, an XC30 system at NERSC.  I compiled with
>>> cray-mpich 7.1.1, and I think it is using Torque as the batch system.
>>> FYI, to run this example program I have to launch the executable using
>>> aprun (otherwise MPI won't initialize properly). I think this will be
>>> reproducible with non-MPI programs as well, though.
>>> thanks,
>>> -Phil
>>> On 05/01/2015 04:53 AM, Cristian Simarro wrote:
>>>> Hi Phil,
>>>> Could you please tell me the batch system that you are using in
>>>> your Cray machine? Is the MPI implementation cray-mpich?
>>>> Thanks,
>>>> Cristian
>>>> To: "Cristian Simarro" <cristian.simarro at ecmwf.int>
>>>> Cc: darshan-users at lists.mcs.anl.gov
>>>> Sent: Thursday, 30 April, 2015 8:45:11 PM
>>>> Thanks for the test program, Cristian. I can confirm that it hangs
>>>> with
>>>> LD_PRELOAD on a Cray, but not on a Linux workstation.  I'm not exactly
>>>> sure what the underlying difference is in this case, but it is
>>>> definitely 100% reproducible in the Cray environment.
>>>> Kalyana Chadalavada has actually observed something very similar when
>>>> using fork() directly; I imagine that it is the underlying fork()
>>>> within
>>>> the system() call that is causing the problem.
>>>> thanks,
>>>> -Phil
>>>> On 04/30/2015 03:07 AM, Cristian Simarro wrote:
>>>>> Hi Phill,
>>>>> Actually any command under system() call is triggering the
>>>>> problem. The spawned process do not finish and then the task that
>>>>> has issued the call is hung on the waitpid.
>>>>> This example hangs if we are using LD_PRELOAD mechanism:
>>>>> #include <stdio.h>
>>>>> #include <mpi.h>
>>>>> #include <stdlib.h>
>>>>> int main (int argc, char *argv[])
>>>>>       int rank, size;
>>>>>       int ret;
>>>>>       MPI_Init (&argc, &argv);
>>>>>       MPI_Comm_rank (MPI_COMM_WORLD, &rank);
>>>>>       MPI_Comm_size (MPI_COMM_WORLD, &size);
>>>>>       if(rank == 0) {
>>>>>        ret = system("echo calling system");
>>>>>       printf( "Hello world from process %d of %d\n", rank, size );
>>>>>       MPI_Finalize();
>>>>>       return 0;
>>>>> Thanks,
>>>>> Cristian
>>>>> Cristian Simarro
>>>>> Sent: Wednesday, 29 April, 2015 10:13:54 PM
>>>>> On 04/29/2015 02:54 PM, Phil Carns wrote:
>>>>>> On 04/29/2015 12:17 PM, Cristian Simarro wrote:
>>>>>>> Hello,
>>>>>>> We have been facing some problems with system() call inside some
>>>>>>> C/Fortran codes in our Cray machine.
>>>>>>> The method used here is compile dynamically and then use
>>>>>>> LD_PRELOAD.
>>>>>>> When the code calls system(command), it hangs the execution if
>>>>>>> preloaded with Darshan because it is trying to instrument an
>>>>>>> internal
>>>>>>> system read() with no initialization.
>>>>>>> The solution we have designed is to unset LD_PRELOAD (if set
>>>>>>> before)
>>>>>>> in the darshan_mpi_initialize function.
>>>>>>> Has anybody found a similar problem with LD_PRELOAD + system()
>>>>>>> calls?
>>>>>> Hi Cristian,
>>>>>> I don't think I've seen this exact combination before, but it seems
>>>>>> like something we should be able to reproduce and isolate.
>>>>>> If I understand correctly, it sounds like the underlying process
>>>>>> spawned by system() is inheriting the LD_PRELOAD environment
>>>>>> variable
>>>>>> from the parent program, and it is the underlying process that is
>>>>>> getting hung?  If so, does it matter what you run in the system()
>>>>>> call
>>>>>> or does it seem like pretty anything triggers it?
>>>>>> thanks,
>>>>>> -Phil
>>>>> The solution you have suggested (unsetting LD_PRELOAD grammatically
>>>>> during Darshan initialization) might not be a bad long term solution,
>>>>> maybe with some extra safety logic to make sure we don't accidentally
>>>>> unset unrelated LD_PRELOAD entries.  I imagine that once the
>>>>> application
>>>>> has gotten to darshan initialization, then the loader has already
>>>>> processed the LD_PRELOAD environment variable and we don't need to
>>>>> keep
>>>>> it set any longer.  That would help keep it from interfering with
>>>>> child
>>>>> processes.
>>>>> We would definitely need to do some testing to confirm, though.
>>>>> thanks,
>>>>> -Phil
>>>>> _______________________________________________
>>>>> Darshan-users mailing list
>>>>> Darshan-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
debug trace [15729]: read called by 0x45b3ff [ libpthread.so.0(0x2ab0c541b000) read(0x2ab0c5429790) ].
libread-wrapper.so: current_fn: 0x2ab0c4aefa20, dlsym fn: 0x2ab0c5429790, pid: 15729, exe: /usr/bin/perl.
debug trace [15729]: read called by 0x506075 [ libpthread.so.0(0x2ab0c541b000) read(0x2ab0c5429790) ].
debug trace [15730]: read called by 0x2b509748b326 [ libpthread.so.0(0x2b509778d000) read(0x2b509779b790) ].
libread-wrapper.so: current_fn: 0x2b5097182a20, dlsym fn: 0x2b509779b790, pid: 15730, exe: /usr/bin/python.
debug trace [15734]: read called by 0x469946 [ libc.so.6(0x2b30f6e12000) __read(0x2b30f6ee03b0) ].
libread-wrapper.so: current_fn: 0x2b30f6759a20, dlsym fn: 0x2b30f6ee03b0, pid: 15734, exe: sh.
debug trace [15729]: read called by 0x4ce011 [ libpthread.so.0(0x2ab0c541b000) read(0x2ab0c5429790) ].
debug trace [15738]: read called by 0x2b5c01bd0162 [ libpthread.so.0(0x2b5c025ff000) read(0x2b5c0260d790) ].
libread-wrapper.so: current_fn: 0x2b5c01739a20, dlsym fn: 0x2b5c0260d790, pid: 15738, exe: /opt/cray/alps/default/bin/aprun.
debug trace [15738]: read called by 0x2b5c019b270a [ libpthread.so.0(0x2b5c025ff000) read(0x2b5c0260d790) ].
debug trace [15738]: read called by 0x416217 [ libpthread.so.0(0x2b5c025ff000) read(0x2b5c0260d790) ].
debug trace [15738]: read called by 0x2b5c019b1900 [ libpthread.so.0(0x2b5c025ff000) read(0x2b5c0260d790) ].
debug trace [15758]: read called by 0x40b478 [ libc.so.6(0x2aea6d735000) __read(0x2aea6d8033b0) ].
libread-wrapper.so: current_fn: 0x2aea6d4c2a20, dlsym fn: 0x2aea6d8033b0, pid: 15758, exe: /usr/bin/gzip.
debug trace [48712]: read called by 0x2aaaaf0e44e9 [ libpthread.so.0(0x2aaaabf53000) read(0x2aaaabf61790) ].
libread-wrapper.so: current_fn: 0x2aaaaaccca20, dlsym fn: 0x2aaaabf61790, pid: 48712, exe: ./test.
debug trace [48712]: read called by 0x2aaaabb20db1 [ libpthread.so.0(0x2aaaabf53000) read(0x2aaaabf61790) ].
debug trace [48713]: read called by 0x2aaaaf0e44e9 [ libpthread.so.0(0x2aaaabf53000) read(0x2aaaabf61790) ].
libread-wrapper.so: current_fn: 0x2aaaaaccca20, dlsym fn: 0x2aaaabf61790, pid: 48713, exe: ./test.
debug trace [48713]: read called by 0x2aaaabb20f33 [ libpthread.so.0(0x2aaaabf53000) read(0x2aaaabf61790) ].
debug trace [48714]: read called by 0x2aaaac3c64e9 [ libc.so.6(0x2aaaab385000) __read(0x2aaaab4533b0) ].
libread-wrapper.so: current_fn: 0x2aaaaaccca20, dlsym fn: 0x2aaaab4533b0, pid: 48714, exe: sh.
debug trace [48714]: read called by 0x2aaaabd4bdb1 [ libc.so.6(0x2aaaab385000) __read(0x2aaaab4533b0) ].
debug trace [48715]: read called by 0x2aaaac3c64e9 [ libc.so.6(0x2aaaab385000) __read(0x2aaaab4533b0) ].
libread-wrapper.so: current_fn: 0x2aaaaaccca20, dlsym fn: 0x2aaaab4533b0, pid: 48715, exe: sh.
debug trace [48715]: read called by 0x2aaaabd4bf33 [ libc.so.6(0x2aaaab385000) __read(0x2aaaab4533b0) ].
=>> PBS: job killed: walltime 160 exceeded limit 120
aprun: Apid 12262186: Caught signal Terminated, sending to application
_pmiu_daemon(SIGCHLD): [NID 00804] [c4-0c0s9n0] [Wed May  6 13:27:51 2015] PE RANK 0 exit signal Terminated
More information about the Darshan-users
