[Darshan-users] unable to LD_PRELOAD PMPI-based profiler with Fortran for Intel compilers?
    Phil Carns
    carns at mcs.anl.gov
    Fri Mar 20 13:25:51 CDT 2015
That's right.  The issue has to do with the MPI library bindings rather
than the underlying compiler.
Unfortunately, Fortran profiling has been problematic across multiple
MPI implementations recently, though.  To summarize all in one place,
Darshan won't instrument Fortran in the following scenarios:
- Fortran (77 or 90) on the MPICH 3.1.1 through 3.1.3 releases (see
http://trac.mpich.org/projects/mpich/ticket/2209)
- Fortran90 on recent IBM BG drivers (see
http://lists.mcs.anl.gov/pipermail/darshan-users/2015-March/000265.html). Fortran77
is fine, though.
- Fortran (77 or 90) on Intel MPI 4.x (see
https://software.intel.com/en-us/forums/topic/279445)
The MPICH issue has been resolved.  The IBM BG issue is still present.
I'm not sure of the status of Intel MPI.  All of these are independent
of which underlying compiler you use.
thanks,
-Phil
On 03/20/2015 01:54 PM, Hedges, Richard M. wrote:
> Should things work with Intel compilers but non-Intel MPI?
> Thanks,
> - Richard
> From: Phil Carns <carns at mcs.anl.gov <mailto:carns at mcs.anl.gov>>
> Date: Friday, March 20, 2015 at 10:35 AM
> To: "darshan-users at lists.mcs.anl.gov
> <mailto:darshan-users at lists.mcs.anl.gov>"
> <darshan-users at lists.mcs.anl.gov <mailto:darshan-users at lists.mcs.anl.gov>>
> Subject: Re: [Darshan-users] unable to LD_PRELOAD PMPI-based profiler
> Hi Richard,
> I'm honestly not sure at this point.  There has been a major release
> of Intel MPI (5.x) since then, so things might be different now.  That
> issue was observed in 4.0.
> thanks,
> -Phil
> On 03/20/2015 01:26 PM, Hedges, Richard M. wrote:
>> Is this still true?
>> Richard Hedges
>> Customer Support and Test - File Systems Project
>> Development Environment Group - Livermore Computing
>> Lawrence Livermore National Laboratory
>> 7000 East Avenue, MS L-557
>> Livermore, CA    94551
>> v:    (925) 423-2699
>> f:    (925) 423-6961
>> E: richard-hedges at llnl.gov
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150320/5d0cbef6/attachment.html>
More information about the Darshan-users
