[Darshan-users] LD_PRELOAD system() call
Phil Carns
carns at mcs.anl.gov
Mon Jun 1 21:00:33 CDT 2015
I gave it a try just now, but unloading the atp module didn't make a
difference for me.
Just to be sure, I unloaded atp, recompiled the application, and then
ran the job while preloading darshan (2.3.0) rather than the read
wrapper test library. The application runs fine and a Darshan log is
produced, but I still get this in stderr:
Mon Jun 1 18:46:12 2015: [unset]:_pmi_alps_sync:alps response not OKAY
Mon Jun 1 18:46:12 2015: [unset]:_pmiu_daemon:_pmi_alps_sync failed
Mon Jun 1 18:46:12 2015: [PE_0]:_pmi_daemon_barrier:PE pipe read failed
from daemon errno = Success
Mon Jun 1 18:46:12 2015: [PE_0]:_pmi_init:_pmi_daemon_barrier returned -1
As a control case (just to double check that the issue is related to
system()/fork() instead of a more general problem), I repeated the
experiment but modifying the test program so that it doesn't call
system(). That ran fine as well, but it did not produce any error
messages to stderr.
thanks,
-Phil
On 06/01/2015 02:56 AM, Cristian Simarro wrote:
> Hi Phil,
> Can you please try to unload the atp module before running with Darshan? I received similar messages when running with atp + darshan.
> Once we have craype installed I will try the System call.
> Thanks,
> Cristian
> From: "Phil Carns" <carns at mcs.anl.gov>
> To: darshan-users at lists.mcs.anl.gov
> Sent: Sunday, 31 May, 2015 2:40:57 PM
> Subject: Re: [Darshan-users] LD_PRELOAD system() call
> Hi Cristian,
> I just tried to narrow this down further again, but Edison is now
> running craype version 2.3.1 and the behavior seems to have changed.
> There is no longer a hang, and the system() call executes correctly. I
> get the following error messages in stderr, though (in addition to the
> wrapper output):
> Sun May 31 06:30:30 2015: [unset]:_pmi_alps_sync:alps response not OKAY
> Sun May 31 06:30:30 2015: [unset]:_pmiu_daemon:_pmi_alps_sync failed
> Sun May 31 06:30:30 2015: [PE_0]:_pmi_daemon_barrier:PE pipe read failed
> Sun May 31 06:30:30 2015: [PE_0]:_pmi_init:_pmi_daemon_barrier returned -1
> -Phil
> On 05/06/2015 04:47 PM, Carns, Philip H. wrote:
>> Hi Cristian,
>> Here are the results from an execution on Edison, with that fprintf
>> added just before the existing one. I think line 260 is probably the
>> last valid line before the hang (the rest are messages printed after the
>> scheduler starts trying to kill the job).
>> thanks,
>> -Phil
>> On 05/06/2015 02:33 PM, Phil Carns wrote:
>>> On 05/05/2015 07:09 AM, Cristian Simarro wrote:
>>>> Hi Phill,
>>>> I have tried your test in our Cray but I can not reproduce the
>>>> behaviour. Actually the test program is finishing properly.
>>> Interesting! I assume it is printing output showing that the wrappers
>>> were triggered, though, right?
>>> I'm attaching my job script just in case there is any difference there
>>> in how we are executing the test case. I think I probably compiled
>>> the example program with Intel compilers, while the read-wrapper
>>> library was compiled with GNU, though I wouldn't think that part would
>>> matter here. The system is running craype 2.2.1.
>>>> Can you add traceback information about the call?
>>>> Dl_info dli;
>>>> original_read = dlsym(RTLD_NEXT, "read");
>>>> dladdr(original_read,&dli);
>>>> fprintf(stderr, "debug trace [%d]: %s "
>>>> "called by %p [ %s(%p) %s(%p) ].\n",
>>>> getpid(), __func__,
>>>> __builtin_return_address(0),
>>>> strrchr(dli.dli_fname, '/') ?
>>>> strrchr(dli.dli_fname, '/')+1 :
>>>> dli.dli_fname,
>>>> dli.dli_fbase, dli.dli_sname, dli.dli_saddr);
>>> Sure, I'll give that a try and report back. Thanks for the example; I
>>> was thinking that a backtrace might be very helpful but I wasn't sure
>>> how to best go about collecting it :)
>>> thanks,
>>> -Phil
>>>> Best regards,
>>>> Cristian
>>>> Cristian Simarro
>>>> Analyst, User Support Section
>>>> European Centre for Medium-Range Weather Forecasts (ECMWF)
>>>> Shinfield Park, Reading, RG2 9AX, United Kingdom
>>>> Tel: (+44 118) 9499315 Fax: (+44 118) 9869450
>>>> E-mail: Cristian.Simarro at ecmwf.int http://www.ecmwf.int
>>>> Sent: Sunday, 3 May, 2015 3:35:46 PM
>>>> Hi Cristian,
>>>> This is definitely the same problem that Kalyana and I were looking at
>>>> earlier with fork(). I built a very small example reproducer library to
>>>> try to simplify the problem (see Makefile and read-wrapper.c). The
>>>> read-wrapper.c isn't doing anything except intercepting the read()
>>>> function, printing some information, then calling the real read()
>>>> function. I've been building this library with PrgEnv-gnu.
>>>> The test.c is your example program, and the
>>>> test-preload-read-wrapper.pbs.e* is an example stderr file from trying
>>>> to run it with the example read wrapper library preloaded.
>>>> There isn't any Darshan code involved here, but the example still
>>>> hangs. It looks like you could trigger it with *any* wrapper on the
>>>> read() function in the Cray environment in conjunction with a fork() or
>>>> system() call. Maybe there is some sort of recursion here?
>>>> I'll keep thinking about this some, but I thought I would share what I'm
>>>> seeing with the list in case anyone else has an idea.
>>>> thanks,
>>>> -Phil
>>>> On 05/01/2015 12:06 PM, Carns, Philip H. wrote:
>>>>> Hi Cristian,
>>>>> I was testing on Edison, an XC30 system at NERSC. I compiled with
>>>>> cray-mpich 7.1.1, and I think it is using Torque as the batch system.
>>>>> FYI, to run this example program I have to launch the executable using
>>>>> aprun (otherwise MPI won't initialize properly). I think this will be
>>>>> reproducible with non-MPI programs as well, though.
>>>>> thanks,
>>>>> -Phil
>>>>> On 05/01/2015 04:53 AM, Cristian Simarro wrote:
>>>>>> Hi Phil,
>>>>>> Could you please tell me the batch system that you are using in
>>>>>> your Cray machine? Is the MPI implementation cray-mpich?
>>>>>> Thanks,
>>>>>> Cristian
>>>>>> To: "Cristian Simarro" <cristian.simarro at ecmwf.int>
>>>>>> Cc: darshan-users at lists.mcs.anl.gov
>>>>>> Sent: Thursday, 30 April, 2015 8:45:11 PM
>>>>>> Thanks for the test program, Cristian. I can confirm that it hangs
>>>>>> with
>>>>>> LD_PRELOAD on a Cray, but not on a Linux workstation. I'm not exactly
>>>>>> sure what the underlying difference is in this case, but it is
>>>>>> definitely 100% reproducible in the Cray environment.
>>>>>> Kalyana Chadalavada has actually observed something very similar when
>>>>>> using fork() directly; I imagine that it is the underlying fork()
>>>>>> within
>>>>>> the system() call that is causing the problem.
>>>>>> thanks,
>>>>>> -Phil
>>>>>> On 04/30/2015 03:07 AM, Cristian Simarro wrote:
>>>>>>> Hi Phill,
>>>>>>> Actually any command under system() call is triggering the
>>>>>>> problem. The spawned process do not finish and then the task that
>>>>>>> has issued the call is hung on the waitpid.
>>>>>>> This example hangs if we are using LD_PRELOAD mechanism:
>>>>>>> #include <stdio.h>
>>>>>>> #include <mpi.h>
>>>>>>> #include <stdlib.h>
>>>>>>> int main (int argc, char *argv[])
>>>>>>> int rank, size;
>>>>>>> int ret;
>>>>>>> MPI_Init (&argc, &argv);
>>>>>>> MPI_Comm_rank (MPI_COMM_WORLD, &rank);
>>>>>>> MPI_Comm_size (MPI_COMM_WORLD, &size);
>>>>>>> if(rank == 0) {
>>>>>>> ret = system("echo calling system");
>>>>>>> printf( "Hello world from process %d of %d\n", rank, size );
>>>>>>> MPI_Finalize();
>>>>>>> return 0;
>>>>>>> Thanks,
>>>>>>> Cristian
>>>>>>> Cristian Simarro
>>>>>>> Sent: Wednesday, 29 April, 2015 10:13:54 PM
>>>>>>> On 04/29/2015 02:54 PM, Phil Carns wrote:
>>>>>>>> On 04/29/2015 12:17 PM, Cristian Simarro wrote:
>>>>>>>>> Hello,
>>>>>>>>> We have been facing some problems with system() call inside some
>>>>>>>>> C/Fortran codes in our Cray machine.
>>>>>>>>> The method used here is compile dynamically and then use
>>>>>>>>> LD_PRELOAD.
>>>>>>>>> When the code calls system(command), it hangs the execution if
>>>>>>>>> preloaded with Darshan because it is trying to instrument an
>>>>>>>>> internal
>>>>>>>>> system read() with no initialization.
>>>>>>>>> The solution we have designed is to unset LD_PRELOAD (if set
>>>>>>>>> before)
>>>>>>>>> in the darshan_mpi_initialize function.
>>>>>>>>> Has anybody found a similar problem with LD_PRELOAD + system()
>>>>>>>>> calls?
>>>>>>>> Hi Cristian,
>>>>>>>> I don't think I've seen this exact combination before, but it seems
>>>>>>>> like something we should be able to reproduce and isolate.
>>>>>>>> If I understand correctly, it sounds like the underlying process
>>>>>>>> spawned by system() is inheriting the LD_PRELOAD environment
>>>>>>>> variable
>>>>>>>> from the parent program, and it is the underlying process that is
>>>>>>>> getting hung? If so, does it matter what you run in the system()
>>>>>>>> call
>>>>>>>> or does it seem like pretty anything triggers it?
>>>>>>>> thanks,
>>>>>>>> -Phil
>>>>>>> The solution you have suggested (unsetting LD_PRELOAD grammatically
>>>>>>> during Darshan initialization) might not be a bad long term solution,
>>>>>>> maybe with some extra safety logic to make sure we don't accidentally
>>>>>>> unset unrelated LD_PRELOAD entries. I imagine that once the
>>>>>>> application
>>>>>>> has gotten to darshan initialization, then the loader has already
>>>>>>> processed the LD_PRELOAD environment variable and we don't need to
>>>>>>> keep
>>>>>>> it set any longer. That would help keep it from interfering with
>>>>>>> child
>>>>>>> processes.
>>>>>>> We would definitely need to do some testing to confirm, though.
>>>>>>> thanks,
>>>>>>> -Phil
>>>>>>> _______________________________________________
>>>>>>> Darshan-users mailing list
>>>>>>> Darshan-users at lists.mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
