[Darshan-users] Darshan-users Digest, Vol 47, Issue 1
Adnan Haider ahaider3 at hawk.iit.edu
Mon Jul 6 17:23:34 CDT 2015
Hey Phil,
After exclusively using LD_PRELOAD, i get the following error:
Darshan failed to map symbol: H5FOpen
Also you are correct; our application during runtime loads mpi4py which
contains the MPI_Init and MPI_Finalize calls.
Thanks, Adnan Haider
B.S Candidate, Computer Science
Illinois Institute of Technology
On Thu, Jul 2, 2015 at 10:00 AM, <darshan-users-request at lists.mcs.anl.gov>
wrote:
> Send Darshan-users mailing list submissions to
>         darshan-users at lists.mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         darshan-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Darshan-users digest..."
> Today's Topics:
>    1. Re: Darshan-users Digest, Vol 45, Issue 6 (Phil Carns)
> Message: 1
> Date: Thu, 2 Jul 2015 09:40:10 -0400
> From: Phil Carns <carns at mcs.anl.gov>
> To: <darshan-users at lists.mcs.anl.gov>
> Subject: Re: [Darshan-users] Darshan-users Digest, Vol 45, Issue 6
> Message-ID: <55953F3A.9020005 at mcs.anl.gov>
> Content-Type: text/plain; charset="windows-1252"; Format="flowed"
> Hi Adnan,
> Python indeed might be a little trickier, but I think its possible.
> I'll see if I can find more information about this and report back.
> I *think* that you need to actually do the reverse and disable the
> static instrumentation and use the dynamic LD_PRELOAD approach instead
> in this case.  I imagine that the Python MPI bindings are dynamically
> loading the MPI library at runtime even though the Python program itself
> doesn't show up as a dynamic executable.
> The critical point in getting a Darshan log to be generated is that it
> must intercept MPI_Init() and MPI_Finalize().  If it can achieve that
> much then it should at least produce a log file.
> Can you try that method again (disabling the static instrumentation and
> instead using LD_PRELOAD exclusively) and confirm the error?
> thanks,
> -Phil
> On 06/29/2015 02:47 PM, Adnan Haider wrote:
> > Hi Phil,
> > Sorry for the late reply, we were focusing on some other aspects but
> > now we are back to using Darshan for analyzing our application. Our
> > executable is statically linked; the previous error was caused by
> > LD_PRELOAD being set in our environment. After resetting LD_PRELOAD
> > (so that we are not dynamically instrumenting), the application runs
> > and there are no symbol mapping errors. However after job completion,
> > no trace file appears in the log directory. We used environment
> > variables with the latest MPICH release in an attempt to statically
> > instrument our application. Compiling a simple mpi application with
> > the environment variables set does produce a Darshan trace file, but
> > our application does not. Also for our executable, using ldd <python
> > script> we get: "not a dynamic executable"
> > Here is some more detail about our application and its dependencies.
> > Our application is written in python. The application uses mpi4py for
> > all MPI calls. Also we are reading and writing netcdf files but are
> > using PyNIO which breaks down python calls into standard netcdf I/O.
> > This site <http://www.alcf.anl.gov/user-guides/darshan> says that
> > dealing with languages other than c,c++,and Fortran could cause
> > issues. I was thinking the python code could be causing the issue.
> > Possibly, the PyNIO package on top of netcdf or mpi4py are not being
> > detected by Darshan. Or more likely, I am not correctly compiling the
> > correct software with the environment variables. The only software
> > that directly uses the mpi compiler is mpi4py, and I did recompile
> > this after setting the environment variables. I also recompiled PyNIO
> > and our application for good measure.
> > On Fri, May 29, 2015 at 10:00 AM,
> >     <mailto:darshan-users at lists.mcs.anl.gov>
> >     <https://lists.mcs.anl.gov/mailman/listinfo/darshan-users>
> >     <mailto:darshan-users-owner at lists.mcs.anl.gov>
> >     Today's Topics:
> >        1. Darshan error with HDF5 (Adnan Haider)
> >        2. Re: Darshan error with HDF5 (Phil Carns)
> >     Message: 1
> >     Date: Thu, 28 May 2015 14:20:07 -0600
> >     From: Adnan Haider <ahaider3 at hawk.iit.edu
> >     <mailto:ahaider3 at hawk.iit.edu>>
> >     To: darshan-users at lists.mcs.anl.gov
> >     Subject: [Darshan-users] Darshan error with HDF5
> >     Message-ID:
> >     <CAM2fH+yEoqtPOnxVPvZNm853kCXEmhWQMrDpWWxZ8UEWC8jUcA at mail.gmail.com
> <mailto:
> CAM2fH%2ByEoqtPOnxVPvZNm853kCXEmhWQMrDpWWxZ8UEWC8jUcA at mail.gmail.com>>
> >     Content-Type: text/plain; charset="utf-8"
> >     Hi,
> >     I am hoping to use Darshan for analyzing our application's
> >     performance. We
> >     are using HDF5 and netcdf 4. I installed Darshan version 2.3.1 and
> >     mvapich2
> >     for our mpi implementation. Darshan works fine for a standard mpi
> >     pingpong
> >     application. When we run our application, however, it gives the
> >     following
> >     error:
> >     Darshan failed to map symbol: H5Fopen
> >     The four instances of the error probably have to do with the 4 mpi
> >     ranks
> >     specified at runtime. Nothing is written into the log directory.
> >     This is
> >     the only output, unless there is some error file I am not aware
> >     of. I used
> >     the static instrumentation approach for enabling Darshan. Thanks
> >     for the
> >     help!
> >     -------------- next part --------------
> >     An HTML attachment was scrubbed...
> >     URL:
> http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150528/5ebdf005/attachment-0001.html
> >     Message: 2
> >     Date: Thu, 28 May 2015 16:32:04 -0400
> >     From: Phil Carns <carns at mcs.anl.gov <mailto:carns at mcs.anl.gov>>
> >     <mailto:darshan-users at lists.mcs.anl.gov>>
> >     Subject: Re: [Darshan-users] Darshan error with HDF5
> >     Message-ID: <55677B44.7060107 at mcs.anl.gov
> >     <mailto:55677B44.7060107 at mcs.anl.gov>>
> >     Hi Adnan!
> >     Is everything in the application statically linked (maybe check
> >     with ldd
> >     <executable>)?  That error message is supposed to only be generated
> by
> >     the dynamic (ld-preloaded) darshan library, because it has to locate
> >     underlying symbols at run time.  The symbol name mapping should be
> set
> >     at link time for a static executable.
> >     thanks,
> >     -Phil
> >     On 05/28/2015 04:20 PM, Adnan Haider wrote:
> >     > Hi,
> >     > performance. We are using HDF5 and netcdf 4. I installed Darshan
> >     > version 2.3.1 and mvapich2 for our mpi implementation. Darshan
> works
> >     > fine for a standard mpi pingpong application. When we run our
> >     > application, however, it gives the following error:
> >     > ranks specified at runtime. Nothing is written into the log
> >     directory.
> >     > This is the only output, unless there is some error file I am not
> >     > aware of. I used the static instrumentation approach for enabling
> >     > Darshan. Thanks for the help!
> >     URL:
> http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150528/bc72a5df/attachment-0001.html
> >     _______________________________________________
> >     Darshan-users at lists.mcs.anl.gov
> >     <mailto:Darshan-users at lists.mcs.anl.gov>
> >     End of Darshan-users Digest, Vol 45, Issue 6
> URL: <
> http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150702/f7894a89/attachment-0001.html
> End of Darshan-users Digest, Vol 47, Issue 1
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150706/9e69492c/attachment-0001.html>
More information about the Darshan-users mailing list
