[Darshan-users] Darshan unable to write log files
Rob Latham
robl at mcs.anl.gov
Thu Feb 26 15:54:34 CST 2015
On 02/26/2015 03:16 PM, Gunter, David O wrote:
> Good call, Rob. Thanks!
> Saving to a non-Panasas directory worked, as did writing to Panasas with the ufs: prefix.
Ok, super strange. When darshan writes the log files, it does it
through MPI-IO, so if one can write via MPI-IO to your panasass file
system, why can't darshan?
the error "MPI_ERR_IO: input/output error" is not very helpful. It's
the error you get if it was not ENAMETOOLONG, ENOENT, ENOTDIR, ELOOP,
EACCES, EROFS.
Last summer I commited some code to ROMIO to also catch EDQUOT, ENOSPC,
and EEXIST.
But even in the "all other cases" case, ROMIO's supposed to call
strerror() and give you something -- anything! -- more helpful than "Uh,
some IO error happened"
What MPI implementation are you using?
==rob
> -david
> David Gunter
> HPC-5: Applications Readiness Team
>> On Feb 26, 2015, at 2:04 PM, Rob Latham <robl at mcs.anl.gov> wrote:
>> On 02/26/2015 02:54 PM, Gunter, David O wrote:
>>> My app writes to a Panasas file system, /scratch/dog/test_prob and I have set
>>> DARSHAN_LOGPATH to /scratch/dog/darshan_logs/
>> this bit, about Panasas, is the only thing that looks out of the ordinary to me.
>> Can you try a non-panasas file system? If not, can you try prefixing the file with ufs: (DARSHAN_LOGPATH=ufs:/scratch/dog/darshan_logs/
>> Did you set up the year/month/day directories?
>> (darshan-runtime/darshan-mk-log-dirs.pl )
>> ==rob
>>> The permissions on the directory are good. My mpi job runs to completion and then I get the error message.
>>> $ mpirun -n 16 ./higrad_driver_noCBE ./params.16pe.in
>>> Total time for simulation = 69.468311
>>> HiGrad simulation is complete!!
>>> Shutting down MPI environment!
>>> darshan library warning: unable to open log file /scratch/dog/darshan_logs/dog_higrad_driver_noCBE_id501442_2-26-49816-14771330631875741401.darshan_partial: MPI_ERR_IO: input/output error
>>> darshan library warning: unable to write log file /scratch/dog/darshan_logs/dog_higrad_driver_noCBE_id501442_2-26-49816-14771330631875741401.darshan_partial
>>> David Gunter
>>> _______________________________________________
>>> Darshan-users mailing list
>>> Darshan-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
>> Rob Latham
>> Mathematics and Computer Science Division
>> Argonne National Lab, IL USA
Rob Latham
More information about the Darshan-users
