[Darshan-users] Darshan 2.3.1-pre2 release
Phil Carns
carns at mcs.anl.gov
Sun Feb 8 09:55:43 CST 2015
Darshan 2.3.1-pre2 is now available on the download
<http://press3.mcs.anl.gov/darshan/download/> page for testing and
feedback. The most significant changes since 2.3.1-pre1 are better
support for recent MPICH releases, examples and documentation for the
-profile hooks in MPICH, and the addition of a regression testing
framework. Our plan is to feature freeze at this point and focus on
platform testing for the final 2.3.1 release.
The full changelog since 2.3.0 is as follows:
darshan-2.3.1-pre2
* added documentation and example configuration files for using the -profile
or $MPICC_PROFILE hooks to add instrumentation to MPICH-based MPI
implementations without generating custom wrapper scripts
* Add wrappers for mkstemp(), mkostemp(), mkstemps(), and mkostemps()
(reported by Tom Peterka)
* Change OPEN_TIMESTAMP field to report timestamp right before open() is
invoked rather than after timestamp after open is completed.
NOTE: updated log format version to 2.06 to reflect this change.
* Change start_time and end_time fields in job record to use min and max
(respectively) across all ranks
* Fix bug in write volume data reported in file system table in
darshan-job-summary.pl (reported by Matthieu Dorier)
* Clean up autoconf test for zlib and make zlib mandatory (reported by
Kalyana
Chadalavada)
* add --start-group and --end-group notation to Darshan libraries for
Cray PE
2.x environment to fix link-time corner cases (Yushu Yao)
* improve y axis labels on time interval graphs in darshan-job-summary.pl
* misc. improvements to darshan-parser --perf output (reported by Shane
Snyder)
- indicate which rank was slowest in unique file results
- label I/O vs. meta time more clearly
- include unique file meta time in agg_perf_by_slowest calculation
* added regression test script framework in darshan-test/regression/
- workstation-static and workstation-dynamic test environments supported
* update darshan-gen-fortran.pl and darshan-gen-cxx.pl to support new
library
naming conventions in MPICH 3.1.1 and higher
* update documentation to reflect known issues with some versions of MPICH
thanks,
-Darshan development team
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150208/e0d8a409/attachment.html>
More information about the Darshan-users
