[Darshan-users] darshan and fluent
Harms, Kevin N.
harms at alcf.anl.gov
Tue Aug 18 09:23:43 CDT 2015
Thomas,
I don't know anything about fluent, but you might inquire what
interfaces they use for I/O.
I would check to see what part of the executable you are running is
dynamically linked as well.
ldd <binary name>
will show what libraries are pulled in via dynamic linking.
kevin
>Hi,
>I try to use darshan to profile the IO of fleunt.
>For that I do
>export LD_PRELOAD=
>/scratch/tgeenen/build/darshan-runtime-icc14.0/lib/libdarshan.so
>and run fluent
>fluent -mpi=intel -g 3ddp -t2 -i journal_lowb
>this does not work.
>After looking into it a bit more carefully I found that in the script
>ansys/15.0.5/v150/fluent/fluent15.0.0/multiport/mpi_wrapper/bin/mpirun.fl
>LD_PRELOAD Is overwritten
>So I hacked it a little,
>FS_MPIRUN_FLAGS="$FS_MPIRUN_FLAGS -genv LD_PRELOAD $LD_PRELOAD"
>Now I get some results but it seems that not all IO is intercepted.
>[tgeenen at ln001 30]$ darshan-job-summary.pl
>tgeenen_fluent_mpi.15.0.0_id24021_7-30-52184-13493803983035018749_1.darsha
>n.gz
>Slowest unique file time: 0
>Slowest shared file time: 0.001565
>Total bytes read and written by app (may be incorrect): 0
>Total absolute I/O time: 0.001565
>Warning: empty y range [0:0], adjusting to [-1:1]
>[tgeenen at ln001 30]$ darshan-summary-per-file.sh
>n.gz output_directory
>Status: Generating summary for file 1 of 1: thermo.db
>darshan-summary-per-file.sh done. Results can be found in
>output_directory/*.pdf.
>[tgeenen at ln001 30]$ ls output_directory/
>thermo.db.gz thermo.db.pdf
>seems that only io for thermo.db is captured
>I posted a question with Ansys support but they seem to be not very
>familiar with darshan.
>I would be interested to understand if other users have experience with
>profiling fluent.
>thanks
>Thomas Geenen
>Project Lead High Performance Computing
>HPC Application & Infrastucture Expert/Architect
>thomas.geenen at asml.com
>-- The information contained in this communication and any attachments is
>confidential and may be privileged, and is for the sole use of the
>intended recipient(s). Any unauthorized review, use, disclosure or
>distribution is prohibited. Unless explicitly stated
> otherwise in the body of this communication or the attachment thereto
>(if any), the information is provided on an AS-IS basis without any
>express or implied warranties or liabilities. To the extent you are
>relying on this information, you are doing so at your
> own risk. If you are not the intended recipient, please notify the
>sender immediately by replying to this message and destroy all copies of
>this message and any attachments. The sender nor the company/group of
>companies he or she represents shall be liable
> for the proper and complete transmission of the information contained in
>this communication, or for any delay in its receipt.
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20150818/14b3dd3a/attachment-0001.bin>
More information about the Darshan-users
