[Darshan-users] Graphics generated by darshan-job-summary.pl
Harms, Kevin N. harms at alcf.anl.gov
Fri May 16 14:32:32 CDT 2014
Thomas,
  I think you should be able to tell from looking in the perl source. For
the most part, the graphs depict totals for files for the whole run. The
"Average I/O cost per process" graph uses the time counters. The "I/O
Operation Counts" use the counters for those items. (writes for write,
stats for stats, etc) "I/O Sizes" use the CP_SIZE counters. "I/O Pattern"
uses CP_CONSEC and CP_SEQ counters. Timespan graphs use the open/close
timestamps of files.
kevin
>Hello,
>I use Darshan in the context of an internship. I generated pdf summaries
>(using darshan-job-summary.pl) and looked at the different graphics. I
>would like to understand more specifically which counters were used for
>each of these graphs ?
>Thank you,
>Thomas Bouguet.
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20140516/d410889a/attachment.bin>
More information about the Darshan-users mailing list
