[Darshan-users] Information on a graph
Phil Carns carns at mcs.anl.gov
Sun Jun 29 09:45:28 CDT 2014
On 06/27/2014 11:04 AM, Matthieu Dorier wrote:
> Hi Darshan users/dev
> I would like some precisions about the first graph in the darshan pdf
> summary (see attached for example).
> There are two bars, one for POSIX and one for MPI-I/O. So if I
> understand correctly, MPI-I/O calls in the POSIX bar will appear in
> purple (label "other"), and so will the POSIX operations in the
> MPI-I/O bar, correct?
Hi Matthieu,
Not exactly.  An example might be the best way to clarify.   Imagine a
job that runs for 100 seconds.  It does an MPI_File_Write for 50
seconds, and that MPI_File_write internally calls a POSIX write for 25
seconds.  The MPI graph will be 50% green and 50% purple.  The POSIX
graph will be 25% green and 75% purple.
Since the POSIX operation was generated as a step within the MPI-IO
operation, it will count towards the MPI-IO write time in the MPI-IO graph.
If you wanted to find out how much time was spent by MPI-IO *not*
including the POSIX operations, then you will have to subtract that out
manually.  We don't have a graph showing that.
thanks,
-Phil
> Thanks,
> Matthieu Dorier
> PhD student at ENS Rennes
> http://people.irisa.fr/Matthieu.Dorier
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20140629/7c91b12f/attachment.html>
More information about the Darshan-users mailing list
