[Darshan-users] Computation of CP_ACCESS[1-4]_ACCESS and other histogram counters
Latham, Robert J. robl at mcs.anl.gov
Thu Feb 27 11:04:16 CST 2014
On Thu, 2014-02-27 at 14:30 +0100, Matthieu Dorier wrote:
> Hi,
> Simple questions out of curiosity:
> I see some counters like, for instance, CP_ACCESS[1-4]_ACCESS (described as "4 most common access sizes"). Does it mean that for each file accessed, Darshan will keep in memory a full histogram of all the access sizes until the end of the program, to be able to get the most frequent ones when writing the log file? If so, isn't it memory-consuming in case of a large number of accesses with different sizes? Besides, why 4? Is it motivated by some analysis that showed 4 to be good enough for most applications?
Darshan does keep a histogram, as you've seen, but the space for that
histogram is bounded by the number of buckets -- and the buckets are
fixed.
The ACCESS counters come from simply a Most Frequently Used list with
four slots.  Again, bounded by the number of slots no matter how crazy
the access pattern might be.
==rob
More information about the Darshan-users mailing list
