[Darshan-users] darshan-job-summary.pl reports non-stop IO
David Shrader dshrader at lanl.gov
Tue May 7 17:34:47 CDT 2013
Hello Kevin,
Thank you for the explanation. It seems I didn't think all the way
through what "first to last access" meant in the context of messing with
the same files multiple times.
Thanks again!
David
On 05/07/2013 04:26 PM, Kevin Harms wrote:
>> Does anyone have any insight on why the job summary seems to depict continuous IO operations? Could the fact that the files are held open even though no IO to disk is actually happening be the reason the graphs suggest continuous IO operations?
>    Yes, the graph shows the the first to last access time. So if you open a file, write to it, close it and do lots of stuff then re-open, update and close it again, you will see a continuous line. This graph "works" for checkpoint type files, where they are opened and used once, so you will see a clean split between the IO phases. Log type files that are modified periodically during the run will look like what you have.
> kevin
More information about the Darshan-users mailing list
