[Darshan-users] cray perftools
Phil Carns carns at mcs.anl.gov
Fri Apr 26 08:42:36 CDT 2013
On 04/26/2013 06:44 AM, jgp wrote:
> Hi,
> I would like to put darshan in production by having its modulefile
> loaded by default for all users. There may be an issue when a user wants
> to compile his code with another tool (CRAY perftools for instance) :
> FATAL: The program '/scratch/santis/piccinal/CRAY+orig' directly or indirectly uses the MPI profiling mechanism.
> Typically, you would avoid this by adding "conflict perftools" in the modulefile of darshan which will stop the loading of darshan if perftools is already loaded. But i am wondering if it would be possible to add a variable in the src code to activate/deactivate darshan on demand. Something like :
> While darshan is always loaded, if a user do :
> module load perftools   # will set DARSHAN_STATUS=OFF and user can compile without darshan
> module rm perftools     # will set DARSHAN_STATUS=ON  and user can compile with darshan
Hi J.G.,
I think that what you described is certainly possible.  If you look in
the compiler script patches, the Darshan instrumentation is already
being toggled on or off based on the $CRAY_DARSHAN_DIR environment
variable (which is set by the darshan module), and it could just as
easily check a $DARSHAN_STATUS variable as well.
I'm curious about the rationale, though - is there a limitation or
problem with the module conflict option?  Unfortunately I am not an
expert on the module system, so I'm still learning these kinds of details :)
-Phil
> I'd like to know the pros/cons. Thanks for your support.
> jg.
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users mailing list
