[Darshan-users] Instrumenting statically-linked applications
Dragos Constantin
dragos.constantin at stanford.edu
Thu Nov 29 13:34:19 CST 2012
Hi Phil,
Thank you for taking time to explain what is going on. Everything is
clear now. I thought darshan uses the same procedures for static and
dynamic libraries.
So, I have introduced the LD_PRELOAD environment variable but I have
issues when I launch the job. I have to work with TACC sysadmins because
there is something in the launch script that hangs the launch procedure.
I will also try to see if TACC sysadmins can generate static libs.
I will keep you posted.
Dragos
Dragos Constantin, PhD
Research Associate
Department of Radiology
Stanford University
Lucas MRS Center
1201 Welch Rd., PS-055
Stanford CA 94305
Office: (650) 736-9961
Fax: (650) 723-5795
On 11/29/2012 8:48 AM, Phil Carns wrote:
> On 11/29/2012 11:35 AM, Dragos Constantin wrote:
>> Hi Phil,
>> I have to recognize I am a bit confused. Let me tell you what I was
>> thinking.
>> 1. The shared and static darshan libraries were generated from the
>> same code, i.e. they contain the same functions.
>> 2. The only difference between them is how these functions are called
>> at run time.
>> 3. Darshan I/O monitoring functions catch any I/O event generated by
>> the application regardless the way the application is compiled.
> No. The darshan.so library can only capture I/O events that are
> handled by shared libraries. The darshan.a library (in conjunction
> with a modified mpicc script) can only capture I/O events that are
> handled by static libraries. You can only use one or the other, not
> both, unfortunately.
>> 4. In my mind both methods should generate the same output regardless
>> the way the program is linked.
>> Now, the Geant4 toolkit have static libraries, hence my application
>> is going to be a mix of static and shared libraries. From what you
>> are saying is that my application should use 100% static libraries or
>> 100% shared libraries. In other words there is no solution for my case.
> No, not at all! Keep doing what you are doing. The solution for the
> way that you are building right now is to use darshan with the
> LD_PRELOAD approach that I described. Darshan does not mind if you
> have a mix of static and shared libaries. It's oblivious to that. The
> only two libraries it cares about (in general) are libc and libmpich.
> As long as those two are dynamic, then you must preload the
> libdarshan.so library to capture I/O events. How you handle the rest
> of your libraries makes no difference at all.
>> How hard it is to modify darshan to work with mixed cases like mine?
> No modification is needed; see above. Darshan has no interest in
> libraries that don't define the symbols that it intends to instrument.
>> I will also try to see if TACC sysadmins can generate static libraries.
> That's up to you. You can use LD_PRELOAD and Darshan with what you
> have now. It basically breaks down like this:
> libc and libmpich are statically linked: use the modified mpicc script
> to inject instrumentation at compile time
> libc and libmpich are dynamically linked: use the LD_PRELOAD method to
> inject instrumentation at run time
> Otherwise the rest is totally up to you as to whether you use a mix of
> static and dynamic libraries or not.
> Does that help?
> I was confused initially because I generally assume that an
> application will either be purely static or purely dynamic, but that
> was just my assumption going in. It isn't a limitation of Darshan.
> thanks!
> -Phil
>> Thanks,
>> Dragos
>> Research Associate
>> Stanford University
>> Lucas MRS Center
>> Stanford CA 94305
>> Fax: (650) 723-5795
>> On 11/29/2012 6:45 AM, Phil Carns wrote:
>>> On 11/29/2012 09:42 AM, Phil Carns wrote:
>>>> On 11/28/2012 11:10 PM, Dragos Constantin wrote:
>>>>> Hi Phil,
>>>>> Here is the ldd output:
>>>> <snip>
>>>>> libmpich.so.1.2 =>
>>>>> /opt/apps/gcc4_4/mvapich2/1.6/lib/libmpich.so.1.2
>>>>> (0x00002b574274a000)
>>>> <snip>
>>>>> libc.so.6 => /lib64/libc.so.6 (0x000000358d400000)
>>>> Hi Dragos, sorry about the wild goose chase, but because these two
>>>> libraries are shared, you will need to use the LD_PRELOAD method to
>>>> capture your I/O calls. The mechanism that you have been using
>>>> (with a modified mpicc script) only works when those libraries are
>>>> statically linked.
>>>>> I believe LD_PRELOAD is used by the dynamic library loader (ld.so)
>>>>> to find the darshan dynamic library 'libdarshan.so'. I might be
>>>>> wrong so please do not hesitate to correct me. In any case, it
>>>>> does not hurt to export this environment variable but if I am
>>>>> right this will not change a thing as 'ld.so' does not touch
>>>>> 'libdarshan.so'.
>>>> The general idea with this approach is that you link your
>>>> application normally at compile time and then set LD_PRELOAD to
>>>> point to libdarshan.so at run time. When your application
>>>> launches, ld.so will link in this LD_PRELOAD library before
>>>> anything else, which gives Darshan a chance to intercept your I/O
>>>> function symbols before they get to libc or libmpich. LD_PRELOAD
>>>> doesn't just set a library path, it actually specifies a specific
>>>> .so file (previously unknown to the application) that the loader
>>>> will link in.
>>>> So the steps that you need to try are as follows:
>>>> 1) recompile and relink your application using the stock mpicc
>>>> (with no darshan modifications). You should not see any darshan
>>>> symbols in the resulting executable.
>>>> 2) add a line like this near the job of your job script:
>>>> #$ -v
>>>> LD_PRELOAD=/full/path/to/your/darshan/installation/lib/libdarshan.so
>>> Just a quick note to anyone else that may run across this in the
>>> list archives; the format of that line is specific to the scheduler
>>> used on Ranger. In general you might just do "export
>>> LD_PRELOAD=..." to set the environment variable or else use whatever
>>> is appropriate for your scheduler or job launcher.
>>> -Phil
>>>> 3) run your application as usual
>>>> I think that should work in your case. As Bill mentioned you do
>>>> need to call MPI_Init() and MPI_Finalize(), but it sounds like you
>>>> are already doing that (otherwise you would not get the empty log
>>>> that you are seeing now), so you should be all set.
>>>> Sorry about the confusion. It is pretty annoying that there isn't
>>>> one method that works for both static and dynamic linking. You
>>>> have to go one way or the other depending on how those libraries
>>>> are used.
>>>> -Phil
>>>> _______________________________________________
>>>> Darshan-users mailing list
>>>> Darshan-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
