[Darshan-users] Instrumenting statically-linked applications
Phil Carns
carns at mcs.anl.gov
Thu Nov 29 08:42:57 CST 2012
On 11/28/2012 11:10 PM, Dragos Constantin wrote:
> Hi Phil,
> Here is the ldd output:
<snip>
> libmpich.so.1.2 => /opt/apps/gcc4_4/mvapich2/1.6/lib/libmpich.so.1.2
> (0x00002b574274a000)
<snip>
> libc.so.6 => /lib64/libc.so.6 (0x000000358d400000)
Hi Dragos, sorry about the wild goose chase, but because these two
libraries are shared, you will need to use the LD_PRELOAD method to
capture your I/O calls. The mechanism that you have been using (with a
modified mpicc script) only works when those libraries are statically
linked.
> I believe LD_PRELOAD is used by the dynamic library loader (ld.so) to
> find the darshan dynamic library 'libdarshan.so'. I might be wrong so
> please do not hesitate to correct me. In any case, it does not hurt to
> export this environment variable but if I am right this will not
> change a thing as 'ld.so' does not touch 'libdarshan.so'.
The general idea with this approach is that you link your application
normally at compile time and then set LD_PRELOAD to point to
libdarshan.so at run time. When your application launches, ld.so will
link in this LD_PRELOAD library before anything else, which gives
Darshan a chance to intercept your I/O function symbols before they get
to libc or libmpich. LD_PRELOAD doesn't just set a library path, it
actually specifies a specific .so file (previously unknown to the
application) that the loader will link in.
So the steps that you need to try are as follows:
1) recompile and relink your application using the stock mpicc (with no
darshan modifications). You should not see any darshan symbols in the
resulting executable.
2) add a line like this near the job of your job script:
#$ -v LD_PRELOAD=/full/path/to/your/darshan/installation/lib/libdarshan.so
3) run your application as usual
I think that should work in your case. As Bill mentioned you do need to
call MPI_Init() and MPI_Finalize(), but it sounds like you are already
doing that (otherwise you would not get the empty log that you are
seeing now), so you should be all set.
Sorry about the confusion. It is pretty annoying that there isn't one
method that works for both static and dynamic linking. You have to go
one way or the other depending on how those libraries are used.
-Phil
More information about the Darshan-users
