[Darshan-users] Instrumenting statically-linked applications
Phil Carns carns at mcs.anl.gov
Wed Nov 28 13:25:13 CST 2012
Hi Dragos,
Could you try this pre-release version of Darshan and us know if it
works for you?
ftp://ftp.mcs.anl.gov/pub/darshan/releases/darshan-2.2.4-pre6.tar.gz
The darshan-gen-* scripts will only work with mvapich2.
I noticed an unrelated issue when trying to test this release on Ranger,
however.  I was not able to build a static executable using mvapich2
(with or without darshan) because it could not find a static version of
the libverbs library. I was trying to generate a static executable by
just adding -static to the mpicc command line.  Maybe there is an
additional step needed to get a fully static executable?
thanks,
-Phil
On 11/27/2012 10:25 AM, Phil Carns wrote:
> Hi Dragos,
> Thanks for the bug report.  It looks like the
> /opt/apps/gcc4_4/mvapich/1.0.1/bin/mpicc is just ordering the link
> arguments differently than darshan-gen-cc.pl expected.  We should be
> able to work around this without too much trouble. In terms of the
> perl code I think we just need to modify the regular expression to
> collect a "$link_cmd_prefix" in addition to a "$link_cmd_suffix" if
> anything appears in the link command line from the first '-' character
> up to the object name.  We can then just pass those arguments as is
> into the generated script.  In this example the link_cmd_prefix would be:
> -Wl,-rpath,/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared -Wl,-rpath-link
> -Wl,/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared
> -L/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared
> I would like to see that particular mpicc script before making any
> changes, though, to make sure that we don't accidentally break
> something, but as (bad) luck would have it Ranger is in maintenance
> today.  We'll have a look at it tomorrow.
> thanks,
> -Phil
> On 11/26/2012 03:27 PM, Dragos Constantin wrote:
>> Hi Kevin,
>> The problem is not with the argument parsing. This is what I get in
>> both cases:
>> login4$ ./darshan-gen-cc.pl /opt/apps/gcc4_4/mvapich/1.0.1/bin/mpicc
>> --output mpicc.darshan
>> CC_from_link = gcc
>> CC_from_compile = gcc
>> Error: cannot find matching CC from: gcc -c foo.c
>> -I/opt/apps/gcc4_4/mvapich/1.0.1/include
>> and: gcc -Wl,-rpath,/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared
>> -Wl,-rpath-link -Wl,/opt/apps/gcc4_4/mvapich/1.0.1/lib/shared
>> -L/opt/apps/gcc4_4/mvapich/1.0.1/lib foo.o -o foo -lmpich
>> -L/opt/ofed//lib64/ -libverbs -libumad -lpthread -lpthread -lrt
>> login4$ ./darshan-gen-cc.pl --output mpicc.darshan
>> CC_from_link = gcc
>> As you can see:
>> but CC_from_link is not gcc and if I am not mistaken it should be
>> gcc. I just started to look at the script and you might know better
>> what is going on here.
>> Thanks,
>> Dragos
>> Dragos Constantin, PhD
>> Research Associate
>> Department of Radiology
>> Stanford University
>> Lucas MRS Center
>> 1201 Welch Rd., PS-055
>> Stanford CA 94305
>> Office: (650) 736-9961
>> Fax: (650) 723-5795
>> ----- Original Message -----
>> From: "Kevin Harms" <harms at alcf.anl.gov>
>> To: "Dragos Constantin" <dragos.constantin at stanford.edu>
>> Cc: darshan-users at lists.mcs.anl.gov
>> Sent: Monday, November 26, 2012 12:23:00 PM
>> Subject: Re: [Darshan-users] Instrumenting statically-linked
>> applications
>>    I think this might be a simple issue with argument parsing. Try
>> this instead:
>> kevin
>> On Nov 26, 2012, at 2:16 PM, Dragos Constantin wrote:
>>> Hi,
>>> I've installed and configured darshan-2.2.3 on TACC Ranger in my
>>> user space. I have used gcc-4.4.5 (and mvapich-1.0.1).
>>> When I try to generate the MPI compiler scripts for
>>> statically-linked applications I get the following error:
>>> I am not quite sure what triggered this. Any ideas how to quickly
>>> fix the issue? I will look at the perl script to see what is going
>>> on there.
>>> Thanks,
>>> Dragos
>>> Research Associate
>>> Stanford University
>>> Lucas MRS Center
>>> Stanford CA 94305
>>> Fax: (650) 723-5795
>>> _______________________________________________
>>> Darshan-users mailing list
>>> Darshan-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users mailing list
