[Darshan-users] Darshan pre-release 2.2.4-pre4
Phil Carns carns at mcs.anl.gov
Tue Nov 20 12:11:58 CST 2012
On 11/20/2012 12:05 PM, Rob Latham wrote:
> On Tue, Nov 20, 2012 at 11:55:52AM -0500, Phil Carns wrote:
>> darshan-2.2.4-pre4
>> * Disable extra stat() of newly opened files by default in order
>>    to improve performance on shared files.  Reported by Yushu Yao.
>>    - prevents Darshan from reporting SIZE_AT_OPEN, FILE_ALIGNENT, and
>>      DARSHAN_FILE_NOT_ALIGNED values
>>    - features can still be enabled via --enable-stat-at-open option
> Hi Phil.  FILE_ALIGNENT is maybe one of the most important metrics for
> understanding poor GPFS write performance.
> ==rob
Hi Rob,
Rob Ross was concerned about this too.  So on GPFS systems we should be
able to keep using stat() like we always have and collect the file
alignment information (I'll be doing some tests next week to confirm).
On Lustre (and other file systems) I'm not sure what to do.  stat() is
the only sure-fire way to detect the file alignment, but it ends up
being very costly because to answer a stat() the kernel also has to
calculate the file size, which in turn requires contacting all servers
and therefore generates quite a bit of overhead if every process does it
simultaneously.  The xstat() system call would probably solve the
problem, but it isn't widely available.
I know of at least two possible workarounds, though neither one is great:
a) If we detect that a file is being opened collectively at the MPI-IO
(or higher) level, then rank 0 could issue a stat() on behalf of all
processes and broadcast the result.  We would still have to skip the
stat in other cases though, because without seeing a collective call we
don't have any way to know how many ranks might open the file.  Its also
unfortunate that we would have to broadcast the stat result, since as a
rule we've generally avoided instigating communication within Darshan
while the application is running.  If we defer aggregating the alignment
until shutdown then the other N-1 processes wouldn't be able to count
the number of unaligned accesses.
b) We could use stat() information collected from the mount point when
Darshan starts up.  The problem with that approach is that the caller
could always change the striping parameters for a file or directory so
that they no longer match the mount point settings.  I would be nervous
about mis-reporting an alignment problem if the application were using
custom file settings.  If we went this route I would at least want to
somehow note in the log whether the alignment data is reliable or if it
is an estimate.
-Phil
More information about the Darshan-users mailing list
