[Darshan-users] Darshan and Intel MPI (x86_64)
Kevin Harms
harms at alcf.anl.gov
Mon Feb 20 13:48:44 CST 2012
what interfaces are you using for I/O? Fortran calls, MPI_File_* routines, something else?
kevin
On Feb 20, 2012, at 1:42 PM, Harr, Cameron Contractor, SAIC wrote:
> Thanks Phil. Using the PRELOAD, I can get a sample output with one of the test C programs that comes with the Darshan source; however, I still don't get any output from my executable. Let me ask a basic question: My app is all Fortran; do I need to compile in any support into Darshan for Fortran compatibility? I see that it should support Fortran, but perhaps I'm doing something wrong.
> On 02/20/2012 10:44 AM, Phil Carns wrote:
>> I don't have any first-hand experience with Intel MPI, but in principle it should work.
>> Does your MPI compiler produces dynamic executables by default? If so, can you try leaving your executable/binary unmodified and load the libdarshan.so library at runtime using the LD_PRELOAD environment variable, rather than directly linking it to your application? There is some more detail about this approach on this page:
>> http://wiki.mcs.anl.gov/Darshan/index.php/Dynamic_linking
>> thanks,
>> -Phil
>> On 02/20/2012 01:28 PM, Harr, Cameron Contractor, SAIC wrote:
>>> I'm trying to get Darshan running on a RedHat/X86_64 cluster with a few different flavors of MPI available. I'm most recently trying Intel MPI and gfortran (Intel Compilers didn't seem to work) and after a fair bit of tweaking, got the executable recompiled with libdarshan.so successfully linked in. In my job run script, I verify that libdarshan is linked in and the job runs to completion; however no output is generated. I also tried setting DARSHAN_INTERNAL_TIMING=1, but still no output. Should I be able to use Intel MPI and/or is there a place that documents which MPI stacks are supported?
>>> _______________________________________________
>>> Darshan-users mailing list
>>> Darshan-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20120220/209f6817/attachment-0001.bin>
More information about the Darshan-users
