[Darshan-users] Darshan 2.2.4 release
Phil Carns
carns at mcs.anl.gov
Thu Dec 13 13:19:53 CST 2012
Darshan 2.2.4 is now available on the download page.
This is primarily a bug fix release, but there is also a performance
optimization for large-scale shared file access on Lustre file systems.
If you are upgrading Darshan on a Cray platform, please re-patch your
compiler scripts. If you are upgrading Darshan on a Blue Gene platform
(P or Q), please check the BG/P recipe in the installation documentation
and note that the –enable-stat-at-open option is now recommended on
those platforms.
Change log:
darshan-2.2.4
* Disable extra stat() of newly opened files by default. This improves
performance on shared files for some platforms. Reported by Yushu Yao.
- prevents Darshan from reporting SIZE_AT_OPEN, FILE_ALIGNENT, and
DARSHAN_FILE_NOT_ALIGNED values
- features can still be enabled via --enable-stat-at-open option
* Fix missing -lz in post ld flags reported by Yushu Yao. Fixes a link-time
error for some corner-case applications.
* Fix bug in Cray compiler script patches that was setting compiler flags
incorrectly. Reported by Yushu Yao.
WARNING: if you are using a previous Darshan release (2.2.3 through
2.2.4-pre4) on a Cray platform, please re-patch your compiler scripts.
* Update darshan-gen-* scripts to support the potential for additonal
LDFLAGS
or CFLAGS that appear before the object or source file in the compile or
link commands. This fixes compatibility with some mvapich2 installations,
reported by Dragos Constantin.
thanks,
-Darshan development team
More information about the Darshan-users
