[Darshan-users] darshan-job-summary.pl fails with path containing underscores
Phil Carns
carns at mcs.anl.gov
Wed Aug 8 10:50:53 CDT 2012
I apologize for taking so long to look at this, but I'd like to
integrate this fix (or something similar to it) in the upcoming 2.2.2
release of Darshan. Do you have a specific example to trigger the
problem that you could share? You can send it directly to me off list.
If not, do you happen to know which portion of the latex file ended up
with an underscore?
The reason that I am curious about the details is because
darshan-job-summary already includes another package (TeX::Encode) that
should be able to account for underscores in file names. I suspect that
we might have missed an instance where we should have encoded a string
using that package. I would like to try to address that issue rather
than use the underscore package if possible because it can protect file
names against other special characters as well.
I will look closer at the perl code and see if I can find any places
where we missed the encoding. I tried a couple of examples on a
development box using underscores but I haven't found the right
combination to trigger the problem yet.
many thanks!
-Phil
On 06/26/2012 09:22 AM, mouhamed.gueye at bull.net wrote:
> Hello,
> With darshan 2.2.0, darshan-job-summary.pl hangs when used on data
> generated from an application doing I/O operations on a filesystem
> that has the underscore character in its name (/home_nfs for example).
> Actually, pdflatex is the one hanging because of that underscore
> character.
> To solve this issue, just add "usepackage{underscore}" into
> darshan-job-summary/share/summary.tex.
> --- darshan-job-summary/share/summary.tex 2012-06-26
> 15:03:46.000000000 +0200
> +++ darshan-job-summary/share/summary.tex.patched 2012-06-26
> 15:03:33.000000000 +0200
> @@ -6,6 +6,7 @@
> \usepackage{lastpage}
> \usepackage{subfigure}
> \usepackage{multirow}
> +\usepackage{underscore}
> % GET THE MARGINS RIGHT, THE UGLY WAY
> Thanks,
> Mouhamed GUEYE
> HPC Engineer
> Phone +33 (0)4 76 29 74 91
> Bull, Architect of an Open World
> http://www.bull.com <http://www.bull.com/>
> Bull World Web TV -> http://www.bull-world.com/
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20120808/28b88688/attachment.html>
More information about the Darshan-users
