[Darshan-users] Error with "darshan-gen-cc.pl"
Phil Carns carns at mcs.anl.gov
Wed Oct 12 08:58:44 CDT 2011
Hi Sandra,
I apologize that this isn't clearer in the documentation, but right now
the darshan-gen-* tools will only work on MPICH-based compiler scripts.
For OpenMPI you will need to either modify the script manually, or else
use the LD_PRELOAD method if your system makes dynamic executables.
-Phil
On 10/12/2011 06:45 AM, Sandra Mendez wrote:
> Hi,
> I try to create the compiler linked with mpicc of the openmpi
> distribution but I have following error:
> smendez at node1:~/darshan-2.1.2-install/install/bin$ ./darshan-gen-cc.pl
> `which /home/smendez/openmpi/bin/mpicc` --output
> ~/darshan-2.1.2-install/install/bin/mpicc-openmpi
> Error: failed to invoke /home/smendez/openmpi/bin/mpicc with -v
> Thanks.
> Sandra.-
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20111012/545457f8/attachment.htm>
More information about the Darshan-users mailing list
