[Darshan-users] darshan output from log
    Kevin Harms
    harms at alcf.anl.gov
    Tue May 24 12:02:07 CDT 2011
Ketan,
  Those files (home/ketan/darshan-install/share/*) should have been copied by 'make install'. darshan-job-summary.pl also requires gnuplot-4.2+ and pdflatex.
  You can check <source dir>/util/share and see if the files are there and then try make install and see where it tries to copy them.
kevin
On May 24, 2011, at 11:47 AM, ketan wrote:
> Hello,
> Now, I have been able to use Darshan as far as generating the Darshan log from the binary execution. However, when I try to generate the output.pdf report as shown in darshan wiki:
> ~/darshan-install/bin/darshan-job-summary.pl ketan_modftdock_id9643_5-24-42129-16735182948803816265_1.darshan.gz --output ~/job-summary.pdf
> I get the following:
> cp: cannot stat `/home/ketan/darshan-install/share/*.gplt': No such file or directory
> cp: cannot stat `/home/ketan/darshan-install/share/*.tex': No such file or directory
> Slowest unique file time: 0
> Slowest shared file time: 0.058647
> Total bytes read and written by app (may be incorrect): 243
> Total absolute I/O time: 0.058647
>         Cannot open load file 'counts-eps.gplt'
>         line 0: util.c: No such file or directory
> EPSTOPDF 2.9.3draft, 2003/04/20 - Copyright 1998-2002 by Sebastian Rahtz et al.
> !!! Error: 'counts.eps' does not exist!
>         Cannot open load file 'hist-eps.gplt'
> !!! Error: 'hist.eps' does not exist!
>         Cannot open load file 'pattern-eps.gplt'
> !!! Error: 'pattern.eps' does not exist!
>         Cannot open load file 'time-summary-eps.gplt'
> !!! Error: 'time-summary.eps' does not exist!
>         "file-access-read-eps.gplt", line 3: undefined variable: font
> !!! Error: 'file-access-read.eps' does not exist!
>         "file-access-write-eps.gplt", line 3: undefined variable: font
> !!! Error: 'file-access-write.eps' does not exist!
>         "file-access-shared-eps.gplt", line 3: undefined variable: font
> !!! Error: 'file-access-shared.eps' does not exist!
> <does not return??>
> Any clue where to find the files (templates?) that it is missing?
> Regards,
> Ketan
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
