[Darshan-users] Darshan installation question
    ketan
    ketan at mcs.anl.gov
    Wed May 18 11:41:52 CDT 2011
I have now installed MPI, however, the installation stops at:
configure: error: must provide --with-jobid-env=<name> argument to
configure.
 From the INSTALL file, I see that if the above option is not provided
Darshan uses the job-id.
Could you kindly indicate how to get past this. Is there a default value
that I could provide here?
Ketan
On 5/17/11 10:11 AM, Kevin Harms wrote:
> Ketan,
>    Darshan itself requires MPI. You could add MPI_Init(), MPI_Finalize() in your program main and that would be sufficient to get information about POSIX calls.
> kevin
> On May 17, 2011, at 10:08 AM, ketan wrote:
>> Hello,
>> I am new to Darshan. Trying to install on ci login node with the following commandline from the INSTALL file:
>> ./configure --with-mem-align=64 --with-log-path=$LOGPATH --prefix=$PREFIX
>> However, I get the following:
>> configure: error: must provide --with-mpi=<path>  argument to configure if mpicc is not in path.
>> The install file does not seem to mention mpi is mandatory. Is it possible to avoid the above flag while installation as our requirement does not include mpi.
>> Thanks,
>> Ketan
>> Darshan-users mailing list
>> Darshan-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
