[Darshan-users] [Bug report] Darshan and Fortran (mpif90)
8schroed at informatik.uni-hamburg.de 8schroed at informatik.uni-hamburg.de
Mon May 2 05:58:54 CDT 2011
Hello,
I tried to run Darshan with Fortran. For testing I wrote a short
program which is using MPICH2 and MPI-I/O (see the attachment
hello-world-mpi.f90).
After compiling the code with Darshan and running the executable,
Darshan didn't generate a logfile. To find the cause I analysed the
Mapfile "$tmpfile" which is created with the build. The main
interesting part in this file shows the symbols of MPI-functions:
                 0x0000000000400b58                mpi_comm_rank_
                 0x0000000000400b68                mpi_file_close_
                 0x0000000000400b78                mpi_file_open_
                 0x0000000000400bd8                mpi_file_write_
                 0x0000000000400be8                mpi_init_
                 0x0000000000400bf8                mpi_finalize_
                 0x0000000000400c08                mpi_comm_size_
But in mpif90 (of Darshan) the "grep"-command in line 84 is searching
for "MPI" in upper case even though "MPI" is written in lower case in
the Mapfile:
                 grep MPI $tmpfile
As a result the script "mpif90" of MPICH2 is executed instead of
Darshan, because "grep" sent an exitcode equal 1. By adding the "-i"
option, "grep" ignores case distinctions and the exit code is equal 0.
Now mpif90 of Darshan will be used and after running the program there
is a logfile in the log directory.
Please take note of this bug and fix it in your Darshan-mpif90 to
avoid the problem of case sensitivity.
Best regards,
Sandra
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20110502/84533465/attachment.bin>
More information about the Darshan-users mailing list
