[Darshan-users] Darshan Calibration
Phil Carns
carns at mcs.anl.gov
Wed Jun 1 12:13:18 CDT 2011
Thanks Ketan. Could you also share one of the *.darshan.gz output files
from darshan? It will have more information in it about exactly which
files were traced by Darshan than what we can see in the summary pdf file.
-Phil
On 06/01/2011 12:25 PM, ketan wrote:
> Phil,
> Following is the output of ldd:
> [login.ci.uchicago.edu:progs]$ ldd modftdock
> not a dynamic executable
> Also attached is the strace output. I am not very much used to
> interpret strace level calls.
> Ketan
> On 6/1/11 10:58 AM, Phil Carns wrote:
>> Hi Ketan,
>> Since this is a single process, you could capture an strace of an
>> execution for confirmation. Could you try this:
>> strace -v my_executable_and_arguments >& output.txt
>> It might point out something that your program is doing that Darshan
>> isn't capturing for some reason.
>> Also, could you share the output of this command to make sure that we
>> understand if your libraries are all statically linked?
>> ldd my_executable
>> thanks,
>> -Phil
>> On 06/01/2011 10:35 AM, ketan wrote:
>>> Hello,
>>> Per my previous mails, I have been now successfully able to use
>>> Darshan for our programs. However, it seems that Darshan reports are
>>> not reflecting the amount of data produced by our program.
>>> More specifically, our program produces about 136K of data while
>>> Darshan plots seem to be reporting only about 1K. To combat this and
>>> to callibrate Darshan, we thought of profiling the UNIX coreutils dd
>>> program with Darshan.
>>> However, while trying to do this, when I insert the MPI_Init() and
>>> MPI_Finalize() in dd source, I get linker errors on compilation.
>>> So, my questions are:
>>> 1. Is there a definitive way of finding how Darshan intercepts the
>>> program?
>>> 2. Can I cross verify with some other tool what Darshan has produced
>>> is indeed consistent?
>>> 3. Are there any calibration parameters that I can set while using
>>> Darshan?
>>> 4. Has someone tried using Darshan with coreutils programs?
>>> Attaching two Darshan reports corresponding to our findings.
>>> Best Regards,
>>> Ketan
>>> _______________________________________________
>>> Darshan-users mailing list
>>> Darshan-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20110601/caa51919/attachment.htm>
More information about the Darshan-users
